Dedekind cut problem in rudin; Problem 20, Chapter 1, Rudin
  • Context: Graduate
  • Thread starter Thread starter saim_
    Cut
The discussion revolves around Problem 20 from Chapter 1 of Rudin, which examines the implications of omitting property (III) from the definition of a Dedekind cut. Participants explore the resulting ordered set's least-upper-bound property, the validity of addition axioms (A1 to A4), and the failure of axiom (A5), which pertains to the existence of additive inverses.
  • One participant seeks clarification on why axiom (A5) fails without property (III) in the context of Dedekind cuts.
  • Another participant suggests considering the set of negative rationals, \mathbb{Q}^-, and its union with zero as the identity for addition, proposing that \mathbb{Q}^- lacks an additive inverse.
  • A later reply acknowledges the initial suggestion and discusses the implications of axiom (A5) failing, indicating a misunderstanding that was clarified.
  • A participant presents a proof attempt demonstrating that if \mathbb{Q}^- had an additive inverse, it would lead to contradictions regarding the nature of elements in \mathbb{Q}^- and their sums.
  • The proof attempt argues that the presence of positive elements in the sum of \mathbb{Q}^- and its supposed additive inverse contradicts the identity property.
Participants do not reach a consensus on the validity of the proof presented. There is ongoing discussion regarding the implications of the failure of axiom (A5) and the nature of additive inverses in the context of the defined sets.
The discussion includes assumptions about the properties of rational numbers and their behavior under addition, which may not be universally accepted without further clarification or proof. The proof attempt relies on specific definitions and properties that may require additional scrutiny.
saim_
I need help with the last part of Problem 20, Chapter 1 of Rudin. Here's the problem:
"With reference to the Appendix, suppose that property (III) were omitted from the definition of a cut. Keep the same definitions of order and addition. Show that the resulting ordered set has the least-upper-bound property, that addition satisfies axioms (A1) to (A4) (with a slightly different zero-element!) but that (A5) fails."
I'm just having trouble proving why A5 would fail without property (III).
Note: The appendix, referred to here, contains construction of reals using Dedekind cuts; property (III) is the requirement that a cut have no largest number; properties A1 to A4 are field axioms of closure, associativity, commutativity and existence of identify for addition. A5 is the property of existence of an additive inverse.
Hi saim! :smile:
Let [itex]\mathbb{Q}^-[/itex] be the set of all negative rationals (excluding zero). You've probably found out that [itex]\mathbb{Q}^-\cup\{0\}[/itex] is the identity for addition. Maybe you can show that [itex]\mathbb{Q}^-[/itex] does not have an additive inverse...
I thought micromass had gone off the rails until I realized he was talking about the situation in which axiom A5 fails!
micromass said:
Hi saim! :smile:
here is my attempt at a proof :-
let us assume that [itex]\mathbb{Q}^-[/itex] has an additive inverse. Let us call it β.
Then [itex]\mathbb{Q}^-[/itex] + β = [itex]\mathbb{Q}^-\cup\{0\}[/itex]
Then there is a p [itex]\in[/itex] [itex]\mathbb{Q}^-[/itex] and a q [itex]\in[/itex] β such that
p + q = 0. (since 0 is an element of [itex]\mathbb{Q}^-\cup\{0\}[/itex]).
But p is negative , thus q has to be positive.
Now , there exists a rational q1 such that 0<q1<q .
Further , [itex]\mathbb{Q}^-[/itex] contains the rational -q1.
By definition of addition ,the set [itex]\mathbb{Q}^-[/itex] + β
must contain an element
s = (-q1) + q.
But s is positive. Thus the set [itex]\mathbb{Q}^-[/itex] + β also has some positive rationals as it's elements, and is hence not the additive identity.
Thus there doesn't exist an additive inverse for [itex]\mathbb{Q}^-[/itex] .
*I wanted to know if this is a valid/proper way of proving what was asked in Rudin. I am new to analysis so wanted to better my proving skills. Sorry for posting in an old thread, but what I wanted to ask was being discussed here. Plus I was struck at precisely the point at which the hint is provided by the PF member - micromass.*
