Particle interchange and z component of spin
The discussion revolves around the interchange of particles and the implications for the z component of spin, particularly in the context of quantum mechanics and the behavior of identical fermions. Participants explore the theoretical underpinnings of particle interchange, symmetry, and the Pauli exclusion principle, with a focus on how these concepts apply to spin states in two-particle systems.
  • Some participants assert that the z component of spin cannot simply be interchanged with position and total spin without potentially resulting in a different state.
  • Others argue that symmetric and antisymmetric combinations of spin states are eigenstates of total spin, suggesting that the original hypothesis about interchangeability may not hold.
  • A participant questions the validity of the original hypothesis, emphasizing that all properties should be interchanged when particles are swapped.
  • Some participants highlight that fermionic wavefunctions must be properly symmetrized, leading to states that do not allow for configurations like \(\uparrow\downarrow\).
  • There is a discussion about the implications of having an equal mix of spin states and how this affects the ability to swap particles without distinguishing their identities.
  • One participant raises concerns about the physical logic of swapping particles with different spin states, suggesting that it seems counterintuitive.
  • Another participant points out that once a measurement is made, the wavefunction collapses, and only one spin state can be observed, which complicates the discussion about swapping particles.
  • Some participants express discomfort with the idea that particles could be swapped even when they are not identical in spin without measurement.
Participants do not reach a consensus; multiple competing views remain regarding the implications of particle interchange and the treatment of spin states. Some agree on the necessity of symmetrization, while others question the physical implications of these mathematical constructs.
Limitations include the dependence on definitions of identical particles and the unresolved nature of how different spin states can be treated in particle interchange scenarios. The discussion reflects ongoing uncertainties in the interpretation of quantum mechanics related to spin and particle identity.
LostConjugate
The one thing that is NOT identical for different particles in a state is the z component of spin, having a probability of being positive or negative.
So when interchanging particles how do you handle the z component of the spin, it simply can't be interchanged along with the position and total spin as you could end up with a different state.
If it is [tex]\uparrow\downarrow[/tex], you do get a different state.
Symmetric and antisymmetric combinations are eigenstates of total spin.
So how can the original hypothesis hold. What happens to the z component of spin, it must be transferred to the swapped particle.
What is "the original hypothesis"?
When interchanging particles, all properties are interchanged.
His point was that if the spin directions are opposite, then the particles are not identical. However of course that is not an issue, because any fermionic wavefunction must be properly (anti)symmetrized. So you never have a state like, [tex]\uparrow\downarrow[/tex] rather you have states like [tex]\frac{1}{\sqrt{2}}(\uparrow\downarrow - \downarrow\uparrow)[/tex] which are properly symmetrized.
[EDIT] that is a very simple example of how the Pauli exclusion principle is applied, and also why it is required.
Everything is interchanged. Indeed, naively, you could end up with a different state. However, those states are just not allowed. The (anti) symmetrization requirements of identical particles severely restricts the possible multiple particle states in the Hilbert Space.
Oh I do see here that not all states satisfy the interchange hypothesis. Only combinations of states. I still do not see how this just makes it OK to swap particles when there is some probability that they have different spin up/down states, physically it is not logical.
You are not thinking about it correctly then ... the whole process of symmetrizing the states is to create wavefunctions where you CANNOT tell when the particles have been exchanged. If you have an equal mix of |up>|down> and |down>|up>, and you flip the spins, you will have and equal mix of |down>|up> and |up>|down> ... nothing has changed.
Ok, so the idea is to carefully select only wave functions where particles can be exchanged.
An equal mix of up/down states for a large number of particles may work well.
What happens when you only have two particles that are involved in the wave function?
The case I have been describing IS a two particle wavefunction.
This puts each particle in a perfect superposition with equal probabilities which then makes "swapping" them non-trivial. Isn't that just a mathematical loop hole? Physically each particle could have opposite spins if measured.
The "mathematical loophole" I described demonstrates how a wavefunction for a two-particle state with paired spins can conform to the Pauli exclusion principle, which we know from experimental evidence must be true. Identical fermions obey Fermi-Dirac statistics (another experimental fact) ... therefore writing a wavefunction for a fermion state that doesn't conform to those experimental facts doesn't make any sense. I cannot prove to you that the properly symmetrized wavefunction has any experimental reality .. I can only say that it is consistent with available experimental results, and has never been shown to be wrong.
For that example, they *will* have opposite spins when measured ... what does that have to do with anything? Once you measure the state, you "collapse" the wavefunction, so only one of the two possible components of the superposition can be observed. That is why we describe fermions in states like the one I gave as "spin-entangled".
That helps clear it up.
I suppose because it is uncomfortable knowing that even without measurement you could be swapping spins that are not identical.
  • · Replies 42 ·
