| New Reply |
Confusion with lower/raising indices |
Share Thread | Thread Tools |
| Jun6-11, 10:30 PM | #18 |
Confusion with lower/raising indicesLet's forget about GR for a second and just talk about SR. We have Minkowski coordinates (t,x,y,z). Under a boost, t changes, so it's not a scalar in the sense I'm talking about, right? I agree that if [itex]\tau[/itex] is just some arbitrary number defined as a function on a certain world-line, then the index manipulation in #1 is invalid. The way I would put it is that then, [itex]dA_\sigma/d\tau[/itex] is not a four-vector; when you divide a four-vector by something that isn't a Lorentz scalar, you don't get a four-vector. |
| Jun6-11, 10:51 PM | #19 |
| Jun6-11, 10:51 PM | #20 |
Recognitions:
[tex]\varphi(x) \rightarrow \varphi(x(y))[/tex] where y are the new coordinates. By contrast, a vector field [itex]A^\mu(x)[/itex] would transform as [tex]A^\mu(x) \rightarrow \frac{\partial y^\mu}{\partial x^\nu} A^\nu(x(y))[/tex] where you see there is an additional change of basis. But note that linear coordinate transformations are subsumed under the first equation above. And if you do a non-linear coordinate change (such as changing from Cartesian to spherical coordinates), you will find that only the transformation law for a scalar field makes sense. |
| Jun6-11, 11:06 PM | #21 |
I think the whole issue here revolves around different interpretations of the OP's notation [itex]\tau[/itex]. As far as I can tell, we're all in agreement that if [itex]d/d\tau[/itex] just means some kind of differentiation with respect to an arbitrary real parameter (which is a function of God-knows-what), then the manipulation in #1 is invalid. On the other hand, if it represents differentiation with respect to proper time along a world-line, then I'm pretty sure that the manipulation is valid. |
| Jun6-11, 11:35 PM | #22 |
[tex]F_\mu=\frac{dp_\mu}{d\tau}[/tex] ? What I mean is, is the lowered index on the F so simple as just lowering the index on the p? |
| Jun7-11, 05:16 AM | #23 |
It is remarkable how often this misuse of SR notions confuses differential geometry issues. |
| Jun7-11, 08:36 AM | #24 |
This point is often confused because there are four coordinates, and hence they come with an index. But it's really just a collection of scalars. I'm not too dogmatic about the "geometric" versus "coordinate-based" definitions of tensor fields, but in this case I think the geometric approach makes things much clearer. EDIT: In reading quickly I didn't notice you're thinking of F as the four-force and p as the four-momentum. In this case your expression should indeed be using [itex]F^\nu = u^\mu \nabla_\mu p^\nu = D p^\mu / d\tau[/itex], not the ordinary derivative. This is the standard definition of four-force, so that F^\mu = 0 is the geodesic equation. |
| Jun7-11, 09:35 AM | #25 |
| New Reply |
| Thread Tools | |
Similar Threads for: Confusion with lower/raising indices
| the rule of raising and lowering indices | Quantum Physics | 0 | ||
| Help With Raising and Lowering Indices | Special & General Relativity | 8 | ||
| Help With Raising and Lowering Indices | Differential Geometry | 2 | ||
| Raising and Lowering Indices | Quantum Physics | 6 | ||
