Why can we freely disposal the renormalization conditions?
The discussion revolves around the concept of renormalization in quantum field theory (QFT), particularly focusing on the flexibility of renormalization conditions and the relationship between classical and quantum parameters. Participants explore the implications of changing parameters and the conditions under which these changes are permissible in both classical and quantum frameworks.
  • Some participants question the ability to freely change parameters in the quantum framework, suggesting uncertainty about the implications of such changes.
  • There is a discussion about the condition 1PI=0 at square(p) = -square(M) in the context of renormalization in Phi4 theory, with participants seeking clarity on its justification.
  • Concerns are raised regarding singularities in the renormalization procedure when mass approaches zero, with some participants questioning the validity of the procedure under these conditions.
  • One participant suggests that classical parameters are related to quantum factors, implying that changes in classical parameters affect quantum outcomes, allowing for flexibility in renormalization conditions.
  • Another participant emphasizes that parameters in QFT must be fitted to experimental data and that symmetry principles constrain relationships between quantities, referencing Ward-Takahashi and Slavnov-Taylor identities.
  • There is a repeated inquiry into the acceptance of the Ward-Takahashi identity and its derivation from the symmetry of the action, with some participants expressing confusion about the justification for using symmetric actions.
  • Participants discuss the impact of UV cut-offs on the Ward-Takahashi identity and the singularity issues related to mass, with suggestions that dimensional regularization may be a preferable method for handling divergences.
  • Concerns are raised about the errors associated with using inadequate regularization methods, particularly in relation to the entanglement of counterterms in ordinary renormalization procedures.
  • Some participants note that singularities encountered in Phi4 theory at one-loop perturbation can be addressed through renormalization group methods, but the extent of the errors in ordinary renormalization remains uncertain.
Participants express various viewpoints on the flexibility of renormalization conditions and the implications of parameter changes in quantum frameworks. There is no consensus on the validity of certain renormalization procedures or the best methods for handling singularities, indicating ongoing debate and uncertainty.
Limitations include unresolved questions about the relationship between classical and quantum parameters, the implications of singularities at m=0, and the effectiveness of different regularization techniques. The discussion reflects a range of assumptions and conditions that are not fully explored.
ndung200790
Please teach me this:
The parameters(mass,interaction constant) in classical Lagrangian can be freely changed in classical framwork,but how about in quantum framework?Then why we can freely arrange the renormalization conditions,because I think that we do not know whether the parameters can freely be changed in quantum framework.
Thank you very much in advanced.
And why we can put the condition: 1PI=0 at square(p)= -square(M)(spacelike momentum)(e.g in the renormalization of Phi4 theory)?
In ordinary renormalization procedure,there are some relation with m(mass),that becomes singular at m=0.Then are there any wrong with this renormalization procedure or are there exist the redudancy configuration in case m=0,so in this case there is exist an infinity?
At the moment,I see that the ''classical'' parameters relate with the quantum factors,so we can change the ''classical'' parameters,then the quantum factors are dependently changed.So that we can freely disposal the renormalization conditions.
All the parameters in QFT are not given from theory but have to be fit to experiment. Sometimes relations between quantities are constraint by symmetry principles, particularly local gauge symmetry (Ward-Takahashi/Slavnov-Taylor identities). You find a rather detailed explanation concerning basic renormalization theory in my QFT manuscript:
http://theorie.physik.uni-giessen.de/~hees/publ/lect.pdf
The parameters(mass,interaction constant) in classical Lagrangian can be freely changed in classical framework,but how about in quantum framework?Then why we can freely arrange the renormalization conditions,because I think that we do not know whether the parameters can freely be changed in quantum framework.
The parameters define (both in classical and in quantum mechanics a family of theories,
from which one is picked by the renormalization conditions to match a real system.
Since you repeat the same incorrect phrase over and over again: It should read ''Thank you very much in advance.''
Thanks very much for all your helpfull answers!My English still weak,I am Vietnamese.
By the way,it seem that the Ward-Takahashi identity is accepted at the begining.They accept the corresponding symmetry for the diagrams as a proposition.But why we are permited to do that?
ndung200790 said:
By the way,it seem that the Ward-Takahashi identity is accepted at the beginning.They accept the corresponding symmetry for the diagrams as a proposition.But why we are permitted to do that?
It is _derived_ from the symmetry of the action.
Thus the only question is why we are permitted to use a symmetric action. The answer to that is because it proved to work!
It seem that the symmetry of Lagrangian is not the same symmetry of correlation functions.Then the symmetry of Lagrangian is not the symmetry of corresponding diagrams.The symmetry of the Lagrangian is the same symmetry of correlation only happens when it also is the symmetry of the product of operators of fields at fix spacetime points.
It seem that some UV cut-off violate Ward-Takahashi Identity,some make the dependence on m(mass) that become singularity at m=0.Then what is the best regulation(the cutting-off the UV divergence)?
dimensional regularization seems to be the best for this.
What is the error we meet when we use the ''not good'' regularity?How about the ''wrong'' when we use the ordinary renormalization, in this case, two types of counterterm ''entangle'' with each other(meaning the mass couterterm delta m and scale counterterm delta Z be subtracted at the same time).In the case there is a dependence on m(mass) and it becomes singularity at m=0(S-matrix=...log(.../square(m)))
In Phi4 theory,at one loop pertubative,with dimension regularity,there is a singularity above(...log(.../square(m))).This problem is solved by renomalization group method.But how ''wrong'' is it with the ordinary renormalization procedure?
To find out how wrong something is, one must compute to higher orders or by different, more accurate methods, and compare. I don't know about this particular case.
Doing high accuracy computations in quantum field theory outside the well-trodden paths is always a mix of art and science!
  • · Replies 57 ·
