Topolgy with Thoughtspacezero (youtube)(error?)
  • Context: Graduate
  • Thread starter Thread starter Kidphysics
The discussion revolves around a video on topology, specifically addressing potential errors in the lecturer's explanation of metrics, particularly the Euclidean and max metrics. Participants explore the implications of these metrics in relation to the containment of balls defined by each metric, raising questions about understanding and visualizing these concepts.
  • Some participants suggest that the lecturer may have confused the names of the metrics, which could lead to misunderstandings, but they believe the overall proof remains valid.
  • One participant describes the relationship between the Euclidean and max metrics, noting that the Euclidean ball fits inside the max ball, but questions arise about the implications of this relationship.
  • Another participant attempts to clarify the inequalities between the metrics, stating that the Euclidean distance is generally larger than the max distance, leading to confusion about the containment of the balls.
  • Several participants express uncertainty about the visual representation of the metrics, particularly how the max metric appears to encompass more points than the Euclidean metric despite the latter having a larger radius.
  • One participant introduces an analogy comparing the metrics to walking and cycling distances, suggesting that a larger measure of distance corresponds to a smaller ball in terms of coverage.
  • Another participant reflects on set theory concepts, considering the cardinality of points within the max metric and how this relates to their understanding of distance and radius.
Participants express differing views on the relationships between the metrics and the implications for the containment of the balls. There is no consensus on the correct interpretation of the lecturer's proof or the visual representation of the metrics.
Participants highlight potential confusion stemming from the lecturer's presentation and the need for clearer visual aids. The discussion also reveals varying levels of familiarity with topology concepts, which may affect interpretations.
Kidphysics
This last video I just watched makes me wonder if I am missing something or
perhaps he just made a rather large error. Someone else in the comments pointed out the mistake as well. Was there a mistake in my understanding or was there a mistake in the proof?
thanks in advance guys
I think the lecturer rather unfortunately swapped the names of his metrics about 8 minutes in, which is very confusing! But the gist of the proof remains correct. The point is that if you draw a circle (ball in Euclidean metric) with radius sqrt(2)r, the square of side 2r (ball in max metric) will fit inside it. This should be clear from drawing a picture.
Please allow me to understand the steps that were taken. If i am understanding correctly...
|x1-y1|^2+|x2-y2|^2= d^2(x,y) where d= euclidean metric (that we squared)
now the max metric takes the maximum of either one of these. However, then the max metric would only have one term, where the euclidean has two so we multiply the greater term by two. Now the max metric is still greater than the euclidean metric! Perhaps if we multiplied the Euclidean metric by sqrt(2) and left the max metric radius at 1 then they would become equal but to multiply something that is already larger by two and something that is already smaller by sqrt(2) does not help me understand what I know we want (the Euclidean ball inside the max ball)...
Okay, so let's call the Euclidean metric [itex]d_E[/itex], and the max metric [itex]d_M[/itex] to avoid confusion. We have straightforwardly that for all x,y, [itex]d_M(x,y)\leq d_E(x,y)[/itex], which is the statement that the Euclidean ball fits inside the 'max' ball. We want to also show that [itex]d_E(x,y)\leq \sqrt{2} d_M(x,y)[/itex]. This is the statement that the 'max' ball fits inside the (bigger) Euclidean ball.
It's equivalent to prove the square of this, since everything is positive: [itex]d_E(x,y)^2\leq 2 d_M(x,y)^2[/itex]. WLOG, we can assume [itex]|x_1-y_1|\geq|x_2-y_2|[/itex]. Then [itex]d_E(x,y)^2=(x_1-y_1)^2+(x_2-y_2)^2\leq 2 (x_1-y_1)^2=2d_M(x,y)^2[/itex].
I agree that the video was confusing here. The best way to see what's going on is to draw the picture and let that guide you through the proof.
this may be the root of my confusion. I know that the Euclidean ball fits inside of the max ball.. but I was under the assumption that [itex]d_M(x,y)\geq d_E(x,y)[/itex] since the ball constructed by the max metric is larger than the ball constructed by the Euclidean metric. The reason the circle fits inside the square (I have just started in topology).
I understand the proof and how the max metric 'steals' the largest distance and duplicates it (which is basically what the max metric does, takes the largest distance) to insure it being greater and at worst equal to the Euclidean ball. But wasn't the Max metric always greater? Wasn't the Euclidean ball always in the Max ball? Wouldn't we have to multiply the radius by some constant to the Euclidean radius so that now the square is in the circle?
[PLAIN]http://img51.imageshack.us/img51/6023/problemb.png
as you can tell I want to understand this
I see your confusion. The inequality is the other way round, which is perhaps a little counterintuitive. Think of it like this:
We want to show that the Euclidean ball at x fits inside the max ball at x. So we want to show that every y in the Euclidean ball is also in the max ball. So that means we want to show that if [itex]d_E(x,y)<r[/itex] we also have [itex]d_M(x,y)<r[/itex]. But [itex]d_M(x,y)\leq d_E(x,y)<r[/itex] so we're done.
To see why [itex]d_M(x,y)\leq d_E(x,y)[/itex], look at their squares. The squared Euclidean metric has two terms, and the square of the max metric is equal to the bigger of those two terms. But that still leaves one term over, so the Euclidean distance is the larger one.
Think about the points which are in the max ball (the square) but not in the Euclidean ball (the circle). That means their Euclidean distance from the centre must be larger than r, though there max distance is less than r. This is another clue that the inequality is the right way round.
This indeed does make sense.
I think what is most confusing is the fact that we are plotting the max metric on a Euclidean plane. Looking at the definitions of the two metrics (and squaring) I can see how the Euclidean metric would have a greater radius.. but when plotting on a graph it seems like since the plot of the max metric only takes into account left right up and down, it seems to have a larger set of points! If we draw out a random set of points and draw the balls given by the value of the different radii then the biggest ball will be the one with the bigger radius- the Euclidean ball. Why is it that when the Max metric get's plotted it seems to have more points than the Euclidean ball, yet it is supposed to be smaller and contain an equal if not less amount?
Thank you for all your help thus far
If one measure of distance is larger than another for any two given points, then the balls it describes must be smaller, not larger. Try this analogy:
Let our two metrics be the 'walking' metric and the 'cycling' metric, which they tell us the time in minutes to get between two points by foot or by bike. The bike is faster, so the walking metric between any two points gives us a larger measure of distance. And given an hour, we can get much further on a bike: the balls for the cycling metric are larger.
Okay this is very interesting to me. A problem I'm having is that when I see the box (max metric) I see that there are some points in it that are not contained by the circle. In set theory I think of this as a greater cardinality of ordered pairs? In the set of all points contained by the max metric set.. This could also is a reason that I have been equating larger radius to larger distance.. Although the idea that the cycling metric is bigger because the "range" of the metric per given time "unit"
  • · Replies 28 ·
  • · Replies 23 ·
