Register to reply
Thevenin Equivalent Circuit
by Phillipe
Tags: circuit, equivalent, thevenin
Share this thread:
Phillipe
#1
Jun13-11, 10:37 PM
P: 10
Find the Thevening Equivalent Circuit for the following circuit:
2. Relevant equations
KVL, KCL.
3. The attempt at a solution
First of all, I calculate the current in the middle mesh, which I'll call i2:
[tex] - j25 = ({i_2} - {i_1})(3 + j4) + {i_2}(10)[/tex]
where i1 is the current defined by the current source. Once I've got i2, I multiply that by 10 to get the voltage in the 10 ohm resistor, and after that I calculate Vab using:
[tex]{V_{ab}} = j25 - 10({i_2})[/tex]
However, the result is incorrect (should be 22,2 V with a 98 angle). What am I doing wrong? I've used the same method with other circuits and it worked just fine.
Phys.Org News Partner Science news on Phys.org
Physical constant is constant even in strong gravitational fields
Montreal VR headset team turns to crowdfunding for Totem
Researchers study vital 'on/off switches' that control when bacteria turn deadly
tiny-tim
#2
Jun14-11, 06:28 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
Duplicate to this thread
Register to reply
Related Discussions
Thevenin equivalent circuit Engineering, Comp Sci, & Technology Homework 5
Thevenin Equivalent Circuit Engineering, Comp Sci, & Technology Homework 4
Thevenin equivalent circuit Advanced Physics Homework 2
CIRCUIT ANALYSIS: FInd the Thevenin equivalent of the circuit. 2 res - 1 IVS - 1 VCVS Introductory Physics Homework 2
