| New Reply |
Is there a rigourous proof of 1 = 0.999...? |
Share Thread | Thread Tools |
| Jun14-11, 07:14 PM | #1 |
Admin
Yes. First, we have not addressed what 0.999... actually means. So it's best first to describe what on earth the notation [tex]b_0.b_1b_2b_3...[/tex] means. The way mathematicians define this thing is [tex]b_0.b_1b_2b_3...=\sum_{n=0}^{+\infty}{\frac{b_n}{10^n}}[/tex] So, in particular, we have that [tex]0.999...=\sum_{n=1}^{+\infty}{\frac{9}{10^n}}[/tex] But all of this doesn't really make any sense until we define what the right-hand side means. There is an infinite sum there, but what does that mean? Well, we put [tex]S_k=\sum_{n=1}^{k}{\frac{9}{10^n}} \ ,[/tex] then we have a finite sum. So, for example [tex]S_1=0.9, \ ~S_2=0.99, \ ~S_3=0.999, \ etc.[/tex] So, in some way, we want to take the limit of this sequence. Let's consider a particularly simple sequence to illustrate the idea behind the definition of a limit of a sequence: 1/2, 1/3, 1/4,... The terms in this sequence get smaller and smaller. You might think that it's obvious that it goes to 0, or that it's obvious that a smart mathematician can prove that it goes to 0, but it's not. It's impossible to even attempt a proof until we have defined what it means for something to go to 0. So we have to define what the statement "1/2, 1/3, 1/4,... goes to 0" means, before we can attempt to prove that it's true. This is the standard definition: "1/n goes to 0" means that "for every positive real number [itex]\epsilon[/itex], there's a positive integer N, such that for all integers n such that [itex]n\geq N[/itex], we have [itex]|1/n| < \epsilon[/itex]". With this definition in place, it's quite easy to prove that "1/n goes to 0" is a true statement. What I want you to see here, is that we chose this definition to make sure that this statement would be true. The first mathematicians who thought about how to define the limit of a sequence might have briefly considered definitions that make the statement "1/n goes to 0" false, but they would have dismissed those definitions as irrelevant, because they fail to capture the idea of a limit that they already understood on an intuitive level. So the real reason why 1/n goes to 0 is that we wanted it to! Similar comments hold for the sequence of partial sums that define 0.999... It goes to 1, because we have defined the concepts "0.999....", "sum of infinitely many terms", and "limit of a sequence" in ways that make 0.999...=1. Can we define number systems such that 1=0.999... does not hold? Of course! But these number systems are not as useful, because they don't conform to our intuition about limits and numbers. Now that we know what a limit and an infinite sum is, let me give a fully rigourous proof to the equality 1=0.999... This proof is due to Euler and it appears in the 1770's edition of "Elements of algebra". Does this proof look familiar? It should! It is essentially the same as Proof #2 in the previous post. The only difference is that every step is now justified by operations with limits. The following forum members have contributed to this FAQ: AlephZero Fredrik micromass tiny-tim vela |
| New Reply |
| Thread Tools | |
Similar Threads for: Is there a rigourous proof of 1 = 0.999...?
| Proof Involving Continuity, Irrational Numbers From Elementary Proof Class | Calculus & Beyond Homework | 1 | ||
| How is the epsilon delta proof an actual proof? | Calculus | 7 | ||
| Comparison Proof via axioms, almost done need hints for finish and proof read | Calculus & Beyond Homework | 1 | ||
| Ready for first year rigourous calculus? | Academic Guidance | 13 | ||
| A proof is a proof---says Canadian Prime Minister | General Math | 0 | ||
