Register to reply
Describing the exponential function y=2e^-0.5x^2
by jay17jay
Tags: describing, exponential, function, y2e05x2
Share this thread:
jay17jay
#1
Jun15-11, 12:49 PM
P: 7
Use the function y=2e^-0.5x^2 to answer the following questions
a) state the domain
b) Determine the intercepts, if any
c) Discuss the symmetry of the graph
d) Find any asymptotes
e)determine the intervals of increase and decrease
f)what is the maxima and/or minima
g) where is the curve concave upwards and downwards?
h) locate the points of inflection
2. Relevant equations
3. The attempt at a solution
im having the most difficult with understanding this function since i have never worked with anything like this but this is what i have so far, i would appreciate help me with the steps i have done wrong or dont know how to complete
a) state the domain
-22<x<22
y-intercept: y=2 the point is (0.2)
x-intercept: there are no x-intercepts
the graph is symmetric with respect to the y-axis, as the original equation is unchanged when x is replaced by -x
vertical asymptotes: as x approaches -22, e^x decreases to 0; and as x approaches 22 e^x decreases to 0. Therefore the y-axis is a vertical asymptote.
vertical asymptotes: there are no vertical asymptotes as the graph never crosses the x axis
y=2e^-0.5x^2
dy/dx=2e^-0.5x^2 * d/dx (-0.5x^2)
dy/dx= -3xe^-0.5x^2
since the sign of the first derivative is the different then the sign of x
dy/dx<0 when x>0, and dy/dx<0 when x>0
( im pretty sure that ones wrong)
Max: (0,2)
Min: 0 (not sure about that)
dy/dx=-3xe^-0.5x^2
second derivative:
-3x d/dx(e^-0.5x^2) + e^-0.5x^2 d/dx (-3x)
-3x * e^-0.5x^2 * 2x + e^-0.5x^2 * -3
= -3e^-0.5x^2 (3x^2 +1)
the second derivative is negative meaning the graph is concave down
there are no inflection points
(unsure about that aswell)
i know this is so long but i would really appreciate help on this problem i would like to learn how to do this right.
Phys.Org News Partner Science news on Phys.org
'Office life' of bacteria may be their weak spot
Lunar explorers will walk at higher speeds than thought
Philips introduces BlueTouch, PulseRelief control for pain relief
Mark44
#2
Jun15-11, 01:06 PM
Mentor
P: 21,402
Quote Quote by jay17jay View Post
Do you mean y = 2e^(-.5x^2)?
a) state the domain
a) state the domain
-22<x<22
How did you get this? The domain is all real numbers.
We usually represent points in the plane as a pair of numbers separated by a comma. The y-intercept is (0, 2).
You have two sections for vertical asymptotes and none for horizontal asymptotes. There are several things wrong here:
1) The function is not e^x, which is positive for all real x. e^(-22) is larger than zero. e^22 is a very large number.
2) Whether the graph crosses the x-axis has nothing to do with vertical or horizontal asymptotes.
y=2e^-0.5x^2
dy/dx= -3xe^-0.5x^2
Your derivative is incorrect. It should be dy/dx = -2xe^(-.5x^2)
Max: (0,2)
dy/dx=-3xe^-0.5x^2
second derivative:
jay17jay
#3
Jun15-11, 02:24 PM
P: 7
thankyou for your help yes it is 2e^(-o.5x^2)
and iv looked over your comments and tried this again this is what i came up with still have difficulty on some parts
a) state the domain
- the domain is all real numbers
- y-inter (0,2)
- x-inter are non
- the graph is symmetric with respect to the y-axis, as the original equation is unchanged when x is replaced by -x
- im really confused how to do this now??
- y=2e^-0.5x^2
dy/dx= -2xe^-0.5x^2
since the sign of the first derivative is the different (neg) then the sign of the function
-the graph rises when xE (-22,0) and falls when xE(22,0). the turning point occurs when x=0, y=2.
Max: (0,2)
im having trouble with the second derivative
i have:
= -2x d/dx (e^-0.5x^2) + e^-0.5x^2 d/dx(2x)
= -2x * (-0.5x^2)e + e^(-0.5x^2) * -2
(x^3)e + -2e^(-0.5x^2)
but im not sure if thats right or where to go from there
i do know that the second derivative should be negative for all x, becuase the graph is concave downwards
inflection point at (0,2) ???
Ray Vickson
#4
Jun15-11, 02:37 PM
Sci Advisor
HW Helper
Thanks
P: 5,200
a) state the domain
a) state the domain
-22<x<22
y=2e^-0.5x^2
dy/dx= -3xe^-0.5x^2
Max: (0,2)
dy/dx=-3xe^-0.5x^2
second derivative:
Why do you restrict x to between -22 and 22? What prevents me from substituting x = 175 into the formula for f(x), Why can't I put x = -500? Maple can do it:
f:=exp(-x^2/2):
evalf(subs(x=75,f));
-1221
0.3521840206 10
(this is 0.3521840206e(-1221))
evalf(subs(x=-500,f));
-54286
0.1547968410 10
(this is 0.1547968410e(-54286))
Of course, in something like a spreadsheet the program will print out "0" (or else give an underflow warning), but it is not really zero; it is just smaller then the smallest number that program can handle.
Theoretically, f(x) = exp(-x^2/2) is defined for ALL real x; there is not upper or lower limit.
RGV
Mark44
#5
Jun15-11, 02:53 PM
Mentor
P: 21,402
For vertical asymptotes, are there any values of x for which y is undefined?
For horizontal asymptotes, do the y values approach a specific value as x approaches infinity or neg. infinity?
- y=2e^-0.5x^2
As already mentioned, you need to write this using parentheses.
y = 2e^(-.5x^2)
dy/dx= -2xe^-0.5x^2
You didn't complete your thought here.
dy/dx consists of three factors: -2, x, and e^(-.5x^2).
-2 is (obviously) always negative.
x can be negative, zero, or positive.
e^(-.5x^2) is ALWAYS positive.
On what interval(s) is dy/dx negative?
On what interval(s) is dy/dx positive?
Where is dy/dx equal to zero?
I think that you are using a graphing calculator, and that it is leading you astray. The numbers 22 and -22 play NO ROLE WHATSOEVER in this function.
Max: (0,2)
i have:
First off, never start your work with =. You are finding the second derivative, so the first line could start of with y'' = ...
In your first line, it should be
= -2x d/dx (e^-0.5x^2) + e^-0.5x^2 d/dx(-2x)
In your second line, things go downhill. The derivative of e^(-.5x^2) is -xe^(-.5x^2).
Neither statement is true. The 2nd derivative is NOT always negative, and the graph is NOT concave down everywhere.
Register to reply
Related Discussions
Inverse function of bi-exponential function? Precalculus Mathematics Homework 3
Operator in exponential function and generating function Quantum Physics 1
Describing a function in terms of another Precalculus Mathematics Homework 1
Describing a piecewise function Precalculus Mathematics Homework 3
Exponential function General Math 4
