| New Reply |
Magnetic field inside a cylinder which is rotating in a non-constant angular velocity |
Share Thread | Thread Tools |
| Jun16-11, 02:41 AM | #1 |
A hollow cylinder of length L and radius R, is madeout of a non-conducting material, is charged with a constant surface charge [itex]\sigma[/itex], and is rotating, along its axis of symmetry, with an angular velocity w(t) = [itex]\alpha[/itex]t. 2. Relevant equations 3. The attempt at a solution The answer in the manual is B = [itex]\mu[/itex][itex]\alpha[/itex]tR[itex]\sigma[/itex] Where [itex]\mu[/itex] is ofcurse [itex]\mu[/itex] zero. [ the magnetic constant ]. The manual's solution makes perfect sense if I knew that the circular electric field which is induced by the fact that the magnetic field is changing in time is constant. because then i could say that that the displacement current density is zero. Q: How can derive that the circular electric field, induced by the changing -in-time magnetic field, is not changing with time? Thanks in advance 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| New Reply |
| Thread Tools | |
Similar Threads for: Magnetic field inside a cylinder which is rotating in a non-constant angular velocity
| Magnetic field of long rotating dielectric cylinder with built in radial polarization | Advanced Physics Homework | 3 | ||
| Does Torque act on a disc rotating with constant angular velocity | Classical Physics | 4 | ||
| Rotating square coil in constant magnetic field | Introductory Physics Homework | 2 | ||
| Magnetic field of rotating cylinder | Advanced Physics Homework | 6 | ||
| Rotating cylinder, how long will it take before the angular velocity is halved | Advanced Physics Homework | 2 | ||
