Conservation of energy of speeding truck
The discussion revolves around a physics problem involving the conservation of energy as it pertains to a truck losing its brakes and traveling up a runaway truck ramp. The problem specifically addresses the calculations needed to determine the distance the truck travels along the ramp, given its kinetic energy and the ramp's incline.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the relationship between kinetic energy and potential energy, questioning how to measure height and distance along the ramp. There are discussions about unit conversions and the implications of mechanical energy conservation. Some participants express uncertainty about setting reference points for height and how to relate height to distance traveled up the ramp.
Participants are actively engaging with the problem, offering guidance on how to approach the calculations. There is recognition of the need to account for energy losses in a modified scenario involving a resistive force. Multiple interpretations of the problem setup are being explored, particularly regarding the measurement of height and the implications of ramp length.
Participants mention the importance of unit conversions and the potential confusion arising from different measurement systems. The problem also involves assumptions about the absence of energy losses in the initial scenario, which changes in the subsequent discussion about the resistive force on the ramp.
tre2k3
I tried many ways to perfomr this problem, but i just can't figure out whether or not I am using the right values.
"A 25 ton truck loses it brakes and reaches the bottom of a hill with a speed of 60 mph.
Fortunately, there is a runaway truck ramp which is inclined at angle of 15 degrees to the horizontal."
Assuming no losses, what distance does the truck travel along the runaway truck ramp? (miles) ?
The KE of the truck just before it goes up the ramp is 6010000 ft-lb.
What do I need to do to get the distance the truck travel along the ramp? The length of the ramp is 1 mile if that means anything.
Heres a formula I've used : KE1+PE1+Work=KE2+PE2+Eloss
Since there are no losses, mechanical energy is conserved. Measure PE from the bottom of the ramp, then the intial KE will be completely transformed to PE. Find the height the truck must rise, then figure out how far it must have traveled up the ramp to gain that height. Pay attention to units!
yeah, I think the units will get me. I had to convert from ton and mph to kg and m/s and divide that by 1.36 J just to get ft-lb.
Since I kind of new to this concept, how exactly do I go about measuring the bottom of the ramp. Do I set the value of h to 0 in mgh. Does the length of the ramp matter at all?
Yes, at the bottom of the ramp set h = 0.
Think this way: Set [itex]1/2 m v^2 = mgh[/itex]. Once you find h, relate h to the distance up the ramp (d): [itex]d sin\theta = h[/itex].
nevermind about the length of the ramp, that was justg the distance til the truck gets to the ramp.
i got it :bugeye: :smile: :cool:
One more thing. I having trouble understandin this one.
"If instead of there being no losses, there is gravel on the runaway truck ramp that provides a constant force of 2620 pounds in the opposite direction of motion. What distance does the truck travel along the runaway truck ramp in this case?" (miles)
Do I calculate the energy loss? And do I use cos180 in the equation also?
Yes, you must calculate the work done by that resistive force. Mechanical energy is no longer conserved: the change in energy will equal the work done by that resistive force. You'll find that the truck will stop in a shorter distance up the ramp.
Yes, since the work done by that force is negative.
since i don't know the height in the equation, how do I relate that to the poisition
The same as before: see post #5. You can write your energy equation using only d (distance up the ramp) and not h. Then you'll solve for d, of course.
