Python code for mapping numbers n text file
The discussion centers around a Python script designed to map specific numbers from a text file, specifically targeting pairs of numbers within the same brackets. The user, Balaji, seeks assistance with a code snippet that fails to return expected results when searching for the numbers "4758" and "3895". A solution is provided using regular expressions to isolate and count occurrences of these numbers, with the final implementation leveraging a dictionary to store and retrieve the counts effectively.
  • Familiarity with Python 2.x syntax, particularly the use of raw_input and file handling.
  • Understanding of regular expressions for pattern matching in strings.
  • Basic knowledge of data structures, specifically dictionaries in Python.
  • Experience with reading and processing text files in Python.
  • Learn about Python 2.x file handling techniques, including reading and writing files.
  • Study Python regular expressions using the re module to enhance pattern matching skills.
  • Explore Python dictionaries for efficient data storage and retrieval.
  • Investigate debugging techniques in Python to troubleshoot and resolve code issues effectively.
Programmers, data analysts, and anyone interested in text processing and data mapping using Python, particularly those working with large datasets and requiring efficient number mapping techniques.
Bala06
Dear Programmers
I am having text file having huge data.
From the text file i would like to map the two numbers that are present in the same brackets and the values should not considered if they are present in different numbers.
say for example I want to map number "4758 & 3895" that are in the saem brackets.
I have attached the copy of the data for your reference.
I am expecting the results something like this:
712 0
713 0
714 0
1049 4758 3895 1
1050 4758 3895 1
1051 0
1052 0
1053 0
1054 4758 3895 1
1055 4758 3895 1
where "1" represent the number of counts.
I'm trying python code like this, but its not working.
Code:
def main():
    #Open file for reading
    infile = open('numbers.txt', 'r')
    #Read the contents of the file into a list
    number = infile.readlines()
    #Convert each element into an int
    index = 0
    while index !=len(account_number):
        number = [int(4758 3895) for num in number]
        index +=1
    #Get an the search value
    search = raw_input('Enter a number to search for: ')
    #Determine whether this record matches the search value.
    if search in number:
        print 'Number found.', search
    else:
        print 'The number was not found.'
    #Close the file.
    infile.close()
#Call the main function.
main()
I'm not familiar in python kindly advice.
Many Thanks
Balaji
Technology news on Phys.org
I gave it a crack. I'm sure there's more work for you to do, but that should give you an idea of at least one way to do what you want. Wouldn't be surprised if some python expert can reduce it to 5 lines or something, but that's what I've got. :biggrin:
Trying to explain all this to you would take a loooong time, and I think you'll learn a lot if you just see some code. I try and not post code in this way, generally, so all I ask is that you try and understand what I've written so you learn and it will not be wasted. Time spent learning them is time well spent.
Of course, ask away if you can't figure out something I've done. I put in a few comments that should help. And yes, regular expressions are hard to read and hard to learn. However, you will never regret learning them. They are powerful and supremely useful.
Code:
import re
def main():
    numberDict = {}
    # Iterate over each line in the file
    for line in infile:
        # Match all lines, isolating the key number and data values using
        # regular expression groups
        mo = re.match(r"^(\d+)-hydrogen-bond-frame\.dat\.c\.d\.lw\s\d+-hydrogen-bond-frame\.dat\.c\.d\.pw\s\[(.*)\]", line)
        if mo != None:
            key = mo.group(1)
            data = mo.group(2)
            data = re.sub('[\(\)]', '', data)
            #print "Key: ", key
            #print "Data: ", data
            # Isolate each group of 3 values that go together in the data
            subs = re.findall(r"\d+,\s\'\w+\',\s\'[\w\s]+\'", data)
            numbers = [];
            # Iterate over each substring (group of 3 values) and isolate
            # the first integer, which is what we're interested in
            for substr in subs:
                submo = re.match(r"(\d+),\s\'\w+\',\s\'[\w\s]+\'", substr)
                if submo != None:
                    num = submo.group(1)
                    #print num
                    # Concatenate the numbers into a string with spaces
                    # between each
                    numbers.append(num)
            #print "Value: ", numbers
            # Add all the numbers as the value in the dictionary using the
            # previously isolated key
            # IMPORTANT NOTE: No attempt is made to ensure there are no
            # repeated values.
            if key in numberDict:
                count = numberDict[key][0] + 1
                numberDict[key][0] = count
                numberDict[key] = numberDict[key].append(numbers)
            else:
                numbers.insert(0, 1)
                numberDict[key] = numbers
        else:
            print 'No match.'
    # Done with file, so close it
    infile.close();
    #print numberDict
    if search in numberDict:
        print 'Values: ', numberDict[search]
    else:
main()
Code:
import re
def main():
    numberDict = {}
    for line in infile:
        if mo != None:
            key = mo.group(1)
            data = mo.group(2)
            #print "Key: ", key
            numbers = [];
            for substr in subs:
                if submo != None:
                    #print num
                    # between each
                    numbers.append(num)
            # repeated values.
            else:
        else:
            print 'No match.'
    infile.close();
    #print numberDict
    else:
main()
Dear Grep
Thanks a lot for the code.
Sure i'll try to understand & if any doubts get back to you.
I tried to run the code by mentioning the file in the respective directory & enter the number to search as 4758 3895 for mapping in the same brackets & should be eliminated if they are present in different brackets, but its displays as numbers not found.
kindly advice.
Many Thanks
Balaji
  • · Replies 28 ·
  • · Replies 34 ·
  • · Replies 18 ·
