What is the name of this shape with unequal sides?
  • Thread starter Thread starter Femme_physics
    Shape
The discussion revolves around identifying a geometric shape with unequal sides, initially referred to as a "pentagon" by the original poster. Participants explore the characteristics of the shape and its relation to area calculations.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the definition of a pentagon and the distinction between regular and irregular shapes. There are attempts to relate the shape to area formulas, with suggestions to subdivide the shape into simpler components like parallelograms and triangles. Some participants question the terminology used, such as whether the shape is a parallelogram or a trapezoid.
The discussion is active, with various interpretations of the shape being explored. Participants are providing guidance on how to approach the area calculation, suggesting methods to simplify the problem. There is an acknowledgment of confusion regarding the correct formula and the value of X, but no consensus has been reached on the final answer.
Participants are working within the constraints of homework rules, focusing on understanding the shape and its properties without providing direct solutions. The area of the shape is given as 3375 cm squared, and there are references to specific dimensions related to the variable X.
Femme_physics
Hi FP! :smile:
A pentagon is a good name for this. A pentagon is just a thingy with 5 corners and 5 sides.
It isn't a regular pentagon though, for that we would require all sides and all angles to be equal.
Giant diamond.
Hi micromass! :) (I love this new "hi" thing lol!)
The reason I'm asking is that I'm trying to find X here
http://img10.imageshack.us/img10/3268/yjjjj.jpg
And I know the area is 3375 cm squared. I was hoping the relate the formula for area for this shape to X, but I'm unable to find its formula on my formula page (I can't find the shape, even)
Oh, and there's no "diamond" there :P
Ah, I see. Well, I guess the area of a parallellogram is on your formula page?
Well, let's try to find a formula for the giant diamond (I love that name :biggrin:)
The trick is to subdivide the giant diamond into a parallellogram and a triangle. Just take the two mid-vertices (not the vertices on top and not the vertex on the bottom) and connect them with a line. Now the top is a parallellogram and the bottom is a triangle. Can you find the area of the parallellogram and the triangle?
I think you mean a trapezoid, not a parallelogram.
Yes, indeed. Sorry for the confusion! :blushing:
The figure is symmetrical about that dotted centre line, so concentrate on finding the area of just one of those halves and make it easier for yourself.
Divide the shape up into simpler shapes whose area you can find, viz., rectangles and triangles. Looks like the height of the lowest triangle will be (X - 30). Add the areas together, and equate them to half of 3375 cm2
You end up with one equation and one unknown. Solve for X. :smile:
Hmm.. I see what you're saying! That's brilliant.
I can just take a trapezoid area and add the triangle's area, like thathttp://img695.imageshack.us/img695/5277/triy.jpg
Though from some reason I've still gotten the wrong X. Is this the right equation?
Yes, that seems to be the correct formula. Weird that you find the incorrect X now...
My late Uncle Jor-el says it's our old family crest. He says it should have a big "S" in it.
That's a bit more work than Micromass' method, IMO.
What did you get for X, and what was the answer supposed to be?
It's X = 75 which I actually got -- I forgot to multiply the other side by 2 *oops*
Thanks, everyone!
  • · Replies 16 ·
  • · Replies 47 ·
  • · Replies 19 ·
  • · Replies 42 ·
