New Reply
Power factor of a transformer at 80%
Share Thread
Jun22-11, 10:02 PM   #1
PF is P / S in general. If the transformer is running at 80.1% of full load, the PF should stay the same right since
PF = 0.801P / 0.801S
= P / S
since if the transformer is running at 80.1% full load, the output S and output P would both be 80.1% right? So basically, no matter what load, the PF is constant since the percentage of full load of the transformer cancels out?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jun23-11, 07:39 AM   #2
Recognitions:
Homework Helper Homework Help
The power factor not being exactly unity is due to what, exactly?
I'm trying to understand this. The units of S , are they volt-amperes?
Is the load considered purely resistive in all of this?
What is the equivalent circuit model you are using for your power transformers? Does this give you a clue?
Jun23-11, 08:48 AM   #3
Recognitions:
Quote by fred2028 View Post
= P / S
Hi Fred. What percentage (of it's full load value) do you think the magnetizing current would be when the transformer is running at 80% load current?
New Reply
Similar discussions for: Power factor of a transformer at 80%
Thread Forum Replies
Power Factor/Power Triangle Electrical Engineering 1
power transformer 60 hz to be tested on 50 hz Electrical Engineering 13
Questions related to Current Transformer and Gauge Factor? Electrical Engineering 1
Mutual inductance / coupling factor in twisted wire transformer Electrical Engineering 0
Determine Transformer KVA output and Power Factor Engineering, Comp Sci, & Technology Homework 2
