The PDF of the exponential of a Gaussian random variable
The discussion centers on determining the probability density function (PDF) of the exponential of a Gaussian random variable. Participants explore the mathematical formulation and properties of this transformation, including the use of the Dirac delta function and Jacobian transformations.
  • One participant asks for the PDF of the random variable Y = exp(W), where W is drawn from a Gaussian distribution.
  • Another participant provides a mathematical expression for the PDF of Y using the Dirac delta function and suggests evaluating the integral to find the PDF.
  • A different participant acknowledges the provided method but raises a question about the relationship between the derived PDF and the log-normal distribution, suggesting a potential misunderstanding in the transformation process.
  • Several participants emphasize the importance of including the Jacobian of the transformation in the calculations and inquire about the conditions under which the expressions hold true.
Participants express differing views on the transformation process and the implications for the resulting distribution, indicating that the discussion remains unresolved with multiple competing perspectives on the correct approach.
There are limitations regarding the assumptions made in the transformation process, particularly concerning the Jacobian and the conditions for the validity of the derived expressions.
samuelandjw
What is the PDF of the exponential of a Gaussian random variable?
i.e. suppose W is a random variable drawn from a Gaussian distribution, then what is the random distribution of exp(W)?
Thank you!
The PDF for:
[tex] Y = \exp{\left(\alpha \, X\right)}[/tex]
where the PDF for [itex]X[/itex] is:
[tex] \varphi_{X}(x) = \frac{1}{\sqrt{2 \, \pi} \, \sigma} \, e^{-\frac{(x - a)^{2}}{2 \, \sigma^{2}}}[/tex]
is given by:
[tex] \varphi_{Y}(y) = \int_{-\infty}^{\infty}{\delta(y - \exp(\alpha \, x)) \, \varphi_{X}(x) \, dx}[/tex]
Use the properties of the Dirac delta function to evaluate this integral exactly!
Dickfore said:
The PDF for:
is given by:
Thank you, Dickfore.
I realize I can just use [tex] \varphi_{Y}(y)=\varphi_{X}(x) \frac{dx}{dy}[/tex]
and the result is almost log-normal distribution pdf, but your method looks quite interesting.
I do have a question, in your last integral, suppose [tex]y[/tex] is constant in the integral, then the result would be [tex]\varphi_{Y}(y)=\varphi_{X}(x=\frac{1}{\alpha}\ln{y})[/tex], which is not quite the same as the log-normal. I'm not sure if I have gotten it wrong.
you had forgotten the Jacobian of the transofrmation:
[tex] \left|\frac{d x}{d y}\right|[/tex]
expressed as a function of y. For what values of y do the above expressions make sense?
Thx.
  • · Replies 30 ·
