What Are Control and Signal Regions in Particle Physics Experiments?
  • Context: Graduate
  • Thread starter Thread starter sandiego137
    Explain Susy Terms
This discussion focuses on the definitions and purposes of control and signal regions in particle physics experiments, specifically in the context of QCD (Quantum Chromodynamics) studies using the ATLAS detector. Control regions serve as a means to validate experimental designs by comparing observations with those in the signal region, which directly tests theoretical hypotheses. Key terms such as "true/fake missing transverse energy," "Monte Carlo simulation," and "jet response function" are clarified, providing foundational knowledge for understanding particle physics experiments.
  • Understanding of control and signal regions in experimental physics
  • Familiarity with Monte Carlo simulations in particle physics
  • Knowledge of jet physics and related terminology
  • Basic grasp of QCD and its applications in high-energy physics
  • Research "QCD Monte Carlo methods" for deeper insights into simulation techniques
  • Learn about "jet response functions" and their significance in data analysis
  • Explore the concept of "missing transverse energy" and its implications in experiments
  • Investigate the role of "jet triggers" in data acquisition and event selection
This discussion is beneficial for undergraduate physics students, experimental physicists, and researchers interested in particle physics, particularly those focusing on QCD and data analysis techniques in high-energy experiments.
sandiego137
I am recently reading the articles "Search for squarks and gluinos using final states with jets and missing transverse momentum with the ATLAS detector in sqrt s=7 TeV proton-proton collisions". However, as my limited knowledge, many technical terms that I am understanding as a result I am now struggling with it. By the way, I am second year undergraduate.
I will so appreciate if someone can help me to explain the following:
-what is the purpose of 'control region' and 'signal region'? e.g QCD control region.
-true/fake missing transverse energy.
-Monte Carlo simulation, I often came across the term' QCD Monte Carlo'.
-reversed delta phi cut.
-(jet)response function.
-seed events, smearing. eg. smeared the seed events.(really need explain for this)
-(jet)triggers.
-pseudo-data
-pt balance
-and finally, 'cut' etmiss cut, pt leading jet cut, etc...
I am not very good in English. Hope someone can help me, Thankssss!
It would be better if a real experimental physicist answered your question. However, I do at least speak English, so...
These might be regions of experimental parameter space. Observations in the signal region would be directly testing the hypothesis, observations in the control region might be controls in the sense of experimental design.
"Fake" = wrong, wrongly reconstructed.
http://en.wikipedia.org/wiki/Monte_Carlo_method#Physical_sciences"
A cut https://www.physicsforums.com/showthread.php?t=284486#2" a method of choosing which observations to keep and which to discard. phi might be the angle between jets, delta phi the change in phi. I don't know what the reverse delta phi cut is and couldn't find that phrase in the paper.
A response function describes how one thing responds to another. So this describes how some property of the jet changes in response to another variable.
I think seed events are sample observations used to set phenomenological parameters in the Monte Carlo simulation. Smearing http://plhc2010.desy.de/e43826/e89919/e89941/PLHC2010_poster_Owen.pdf" it's a correction to the raw data from the seed events.
-(jet)triggers.
The trigger is http://aliceinfo.cern.ch/Public/en/Chapter2/Chap2_HLT.html" the neural network which decides whether a particular observation gets recorded.
-pseudo-data
Simulated experimental data (not from real experiments), used to test the information-processing system.
-pt balance
p is momentum, p_T is transverse momentum, p_T balance is probably a measure of how lopsided p_T is.
Explained above.
P.S. For curious readers, http://arxiv.org/abs/1102.5290" .
  • · Replies 0 ·
