The phrase "almost all" is defined in real analysis as "all except for a set of measure zero." The Cantor set has measure zero, so there's no inconsistency between the two articles.
And by the way, although we're both posting a lot of Wiki links here, it's worth mentioning in passing that Wiki is whatever anonymous people type into it. It's not an edited encyclopedia written by authorities in any field. You have to read Wiki with a critical eye.
Yes of course, I misspoke myself and meant to say, "every real number that is not an irrational algebraic."
You are using a very different notion of set formation than is standard in mathematics. The axioms of set theory say nothing about "methods," and in fact there are many sets commonly used in math that can't be constructed at all. One can only prove their existence. The most common example is the Vitali set, which provides the standard example of a nonmeasurable set.
http://en.wikipedia.org/wiki/Vitali_set
Note that the article refers to the "construction" of the set, but that's a misnomer in my opinion. There is an existence proof but not a construction. You can't identify any of the elements of this set.
The Cantor set has a very simple description: It's the set of base-3 expansions of real numbers that don't contain the digit 1. That's no different than defining a set as the union of some other sets.
You will be hard-pressed to come up with a definition of the word "method" that would provide for very many interesting sets; and you would need to rewrite a new version of set theory if you were going to insist that there should be some kind of "method" to defined a set.
I already mentioned that my example is trivial; but it has the virtue of having the property you said you were interested in: it contains only rationals and transcendentals, but no irrational algebraics.
You claim the Cantor set has that property, but that is only conjectured, not proven.
I already pointed out that my set is not very "profound," which is a word you used earlier. But it is formed by the legal rules of set formation; as is the Cantor set. The word "method" is vague. If you want to talk about it, you have to define it.
