Special Functions: Valid Gauss Formula Parameters
The discussion revolves around the validity of parameters in the Gauss formula related to Euler's integral representation. The participants are exploring the conditions under which the Gauss formula converges, specifically focusing on the parameters a, b, and c, and their relationships to each other.
  • Participants are attempting to clarify the conditions for the validity of the Gauss formula, with some suggesting that c must be greater than a+b. Others are questioning the necessity of specific values for a, b, and c, including whether they must be integers or can be complex numbers.
The discussion is active, with various interpretations being explored regarding the parameters' constraints. Some participants have offered guidance on the relationships between the parameters, while others are questioning previous assertions and exploring alternative values.
There is an ongoing debate about the implications of certain values for a, b, and c, particularly concerning the gamma function and its restrictions. Some participants mention that the parameters must meet specific conditions for the formula to be well-defined, while others suggest that there may be more flexibility than previously thought.
Ted123
It is known that Euler's integral representation
[PLAIN]http://img12.imageshack.us/img12/5578/euler.png
is valid for Re(c)>Re(b)>0 and |z|<1.
The series (Gauss Formula)
[PLAIN]http://img830.imageshack.us/img830/2365/gaussz.png
on the other hand converges for Re(c-b-a)>0.
For what values of the parameters a, b and c is the Gauss Formula valid? (Think carefully)
Anyone help?
c must be bigger than a+b ? sorry i mean x must equal 1 for the integral to become the second gamma expression on the nomenator
Where's an x? Do you mean z? I'm not asked to derive the formula here - just to explain what values of a,b,c it is valid for. I was thinking c cannot be a non-negative integer
im sorry ,z must equal 1. the integral is a beta function and is equal to the gamma (the second in the nomenator) of the second function when z = 1
yes c has to be positive and bigger than a+b, and z must equal 1
but the thing is u already mention this, when u wrote Re(c-b-a)>0.
so i don't see what the question is
The full question is this: (I've done part (a) so far which is deriving it...)
[PLAIN]http://img7.imageshack.us/img7/7766/fullqs.png
well b can start from 1 and a from 1 so c must start from 2. I am assuming that the gamma function cannot take negative arguments. last ones just numbercrunching i suppose
Do a,b and c have to be integers? And why does a+b have to be less than c?
How do I compute the sum of the power series with b=-1 for part (c)?
the gamma functions are evaluated using the gauss integral method such that:
gamme (n) = factorial (n-1)
you want the factorial to have integer values as input otherwise it becomes really sad and starts to cry
just plug in the numbers to get those values.
factorial (-1) is a mathematical nonsense, hence why c-b-a must be positive for the function to be welldefined
Part (c) says verify it for b=-1 but you've said that b must start from 1 for it to be valid in part (b)? a,b and c can be complex numbers...
yes you can still have b=-1 with a=0 and c=0 and you will still not run into any trouble.
you can't have for example c=10 with b = 10 and a = 5
you also can't have c=-10 with b = 10 and a = 5
But I thought we established for part (b) that the formula was only valid for a and b starting from 1 and c>2? This shows it can be valid for other values too...
yes i think i made a mistake there again, but trying to minimise c, you can still have c=0 and then move upwards fitting all possible a and b values in
So it looks like as long as [tex]c>a+b[/tex] it will be valid?
yes... and that c is a positive integer
So for part (c), do I have to show that
[tex]\sum_{n=0}^{\infty} \frac{(a)_n(-1)_n}{(c)_n n!} = \frac{\Gamma(c)\Gamma(c-a+1)}{\Gamma(c-a)\Gamma(c+1)}\;?[/tex]
If so, how?
The definition of the shifted factorial (Pochhammer symbol) is:
[tex](a)_n = \frac{\Gamma(a+n)}{\Gamma(a)}[/tex]
i believe if u do the summation in the power series you will find by induction that both represent the same rational number
Still struggling with evaluating either side...
calculate the LHS and confirm it is equal to the RHS?
How do I calculate the LHS though?
ok I am not entirely sure about the notation used in your book, but in my reference books, the a,b,c's on that LHS with the subscripts are pretty hefty recurance relations which I cannot remember off by heart. So you basically just write the numbers in and keep putting new n's. since you have a n! in ur denomenator, youll find that the series converges pretty quickly, maybe after 4-5 terms, then you just calculate and they should be the same
  • · Replies 17 ·
