I designing an overload protection circuit
The discussion revolves around designing an overload protection circuit for a simple electric motor to prevent damage from stalling. Participants explore various circuit components and configurations, focusing on simplicity and avoiding complex integrated circuits.
  • One participant describes the need for a circuit that cuts power after 5-10 seconds of continuous high current flow due to motor stalling, while also allowing for a reset when the motor is no longer stalled.
  • Another participant suggests using a 555 timer in a retriggerable monostable configuration, along with a current sensing circuit, to achieve the desired functionality.
  • A different participant proposes using a resettable fuse (PTC) that would limit current during a short circuit and return to low resistance once the short is removed.
  • One participant expresses concern about their measuring equipment's limitations and indicates familiarity with basic electronic components, seeking a solution that utilizes only those components.
  • Another participant suggests replacing dry cells with rechargeable batteries or adding a series resistance to limit current, noting that this would slow the motor but could be compensated with a capacitor.
  • One participant clarifies their intention for the motor to run at full speed without resistance in its path under normal conditions.
  • There is a reiteration that a PTC fuse is as simple as a resistor, and one participant suggests obtaining free samples from a manufacturer.
Participants present multiple competing views on how to implement the overload protection circuit, with no consensus on a single solution. Various methods are proposed, each with its own advantages and limitations.
Participants express uncertainty about the effectiveness of their measuring equipment and the implications of using different components, such as resistors and capacitors, in the circuit design. There are also unresolved questions regarding the motor's commutator action and its impact on the circuit.
Individuals interested in basic electronics, motor control, and overload protection circuit design may find this discussion relevant.
slapshot136
so I am creating a simple electric motor and I need a circuit that will cut the power if it is stalled (since it can create a short if it is stalled, draining/damaging the batteries) - the problem is that it also creates a short for a small period of time while in regular use
I would like to avoid any complex integrated circuits if possible, as I plan on building this on a block of wood, not a fancy breadboard, and yes I know that the short is an inherent design flaw of the motor, but I would prefer to keep it simple
measurements that may be helpful:
when "shorted" (i.e. the coil is motionless and makes contact), the current is over 15 amps (max of what I can measure) from my 4 D batteries (at 6 volts), so they will drain fast
when running, it draws over 10 amps at times, but I can't get a better reading as it spins rather fast and my needle has a fair bit of delay lag
Ideally this circuit would cut the power after about 5-10 seconds of continuous flow, light up an "error" light, and then re-set itself when the coil was no longer making contact (i.e. it was spun by someone), and allow it to power-up at that time
I assume your electronics knowledge is pretty basic judging by the paper-clip motor set-up (early physics lab).
If not, what do you know/what are you familiar with?
I would suggest reading about 555 timers - I believe the retriggerable monostable configuration would do a lot of what you want. You will need a current sensing circuit, but that is a pretty simple resistor with an op-amp circuit.
http://www.doctronics.co.uk/555.htm#retriggering
Can you check the current again?
Anyway, have a look at resettable fuse - PTC here www.littlefuse.com
The PTC will conduct with very low resistance (milli ohms) during normal current. When a short ckt occurs its resistance goes up (Mega ohms) and limits the current to a small value.
Once the short ckt goes away, its resistance comes back to milli ohms.
It's mostly my meter that is preventing me from getting a good measurement on the current.. I don't want to buy one for just this 1 project
I am familiar with resistors, diodes, capacitors, inductors, and transistors (pnp and npn), and I was hoping to be able to get something using just those - it seems like that isn't possible...
To prolong the life of the dry cells you could replace them with rechargeables. :wink:
Or you could add a resistance in series with the batteries to limit the max current that can be drawn. A piece of nichrome wire, or a suitable car headlight bulb could do. A consequence of this will be that your motor will operate more slowly. You should be able to compensate for this to a large extent by adding a large electrolytic capacitor across the paper clips, and it can supply the rotor's large pulses of current. (Make sure you observe the correct polarity of the capacitor's leads.)
Your commutator action is not clear to me. Are the horizontal wires projecting from the coil i.e., the rotor's shaft) actually a pair of wires each?
I want the motor to run at full speed with no resistor in its path normally..
it's a coated wire where half of the coating has been taking off, such that as it rotates it makes/breaks contact
A PTC fuse is no more complicated than a resistor.
Try getting a few free samples from Littlefuse.com
  • · Replies 27 ·
  • · Replies 51 ·
9K
