New Reply
Converting Sigma notation....
Share Thread Thread Tools
Jun29-11, 01:25 AM   #18
Recognitions:
Gold Membership Gold Member
Quote by Mentallic View Post
So can you apply this to your question now?
How would i apply this to my question?
I like Serena said that define a function of x and integrate it but i still don't get how he got x2k?
Jun29-11, 01:37 AM   #19
Recognitions:
Homework Helper Homework Help
Quote by Pranav-Arora View Post
I defined an arbitrary function s(x) that looks a bit like your problem with the special property that if you substitute x=1, it is identical to your problem.
It's a trick to solve your problem.
The choice of the power 2k was inspired so that the factor (2k+1) would disappear during integration.
Jun29-11, 01:44 AM   #20
Recognitions:
Quote by I like Serena View Post
Ok i got it!!
But how i would integrate the expression. It involves sigma notation and i have never done integration of any expression which involves sigma notation.
Jun29-11, 01:57 AM   #21
Recognitions:
Ok i got it!!
So write out the terms of the summation, do the integration, and combine the resulting terms back into sigma notation.
Jun29-11, 02:08 AM   #22
Recognitions:
I did as you said. After integrating, i got
[tex]x+nx^3+\frac{n(n-1)x^5}{2!}+\frac{n(n-1)(n-2)x^7}{3!}........x^{2n+1}[/tex]
Now what should i do next?
Jun29-11, 02:15 AM   #23
Recognitions:
To be frank, I have never answered such questions myself either, but I took I like Serena's advice and it worked out wonderfully.
We'll start again just to make things clear,
To solve [tex]\sum_{k=0}^{n}(2k+1)^{n}C_k[/tex]
we define a function
[tex]f(x)=\sum_{k=0}^{n}(2k+1){^n}C_kx^{2k}[/tex]
we make it x2k because the integral of that is [itex]\frac{x^{2k+1}}{2k+1}[/itex] and notice how that denominator will cancel with the (2k+1) factor in the original question. So we have,
[tex]\int{f(x)dx}=\sum_{k=0}^{n}{^n}C_kx^{2k+1}[/tex]
And here is the tricky part, we need to convert the right side into a binomial expression using the formula
[tex]\sum_{k=0}^{n}{^n}C_ka^kb^{n-k}=(a+b)^n[/tex]
It is clear that the b is again missing, which it is just hidden as b=1, but we need to convert the x2k+1 in such a way that it is equivalent to ak.
Use your rules for indices to convert it in such a way.
Jun29-11, 02:20 AM   #24
Recognitions:
What might have been easier for you is you could've split the summation into
[tex]2\sum k{^n}C_k+\sum {^n}C_k[/tex]
and then defined [tex]s(x)=2\sum k{^n}C_kx^{k+1}+\sum {^n}C_kx^{k+1}[/tex]
Jun29-11, 02:24 AM   #25
Recognitions:
Hmm, what I intended was this:
[tex]\sum_{k=0}^n {^n}C_k (2k+1) x^{2k}
= {^n}C_0 + {^n}C_1 \cdot 3 x^2 + {^n}C_2 \cdot 5 x^4 + ... + {^n}C_k (2k + 1) x^{2k} + ... [/tex]
Integration would give:
[tex]{^n}C_0 \cdot x + {^n}C_1 \cdot x^3 + {^n}C_2 \cdot x^5 + ... + {^n}C_k x^{2k+1} + ... [/tex]
Converting back to sigma notation:
[tex]\sum_{k=0}^n {^n}C_k x^{2k+1} [/tex]
Jun29-11, 02:27 AM   #26
Recognitions:
Would it be like this (x2k+1+1)n.
Jun29-11, 02:30 AM   #27
Recognitions:
I did the same way.
Jun29-11, 03:07 AM   #28
Recognitions:
Noo...
[tex]\sum{^n}C_kx^k1^{n-k}=(x+1)^n[/tex]
and not [tex](x^k+1)^n[/tex]
Use the fact that
[tex]a^{b+1}=a\cdot a^b[/tex] and [tex]a^{2b}=\left(a^2\right)^b[/tex]
Jun29-11, 03:39 AM   #29
Recognitions:
Noo...
Use the fact that
I tried it but got stuck again. I did it like this:-
[tex]x^{2k+1}=x^{2k}.x=(x^2)^k.x[/tex]
Jun29-11, 04:54 AM   #30
Recognitions:
Why did you get stuck? That's exactly what it should be!
So now we have
[tex]\int{f(x)dx}=\sum_{k=0}^{n}{^n}C_kx\cdot \left(x^2\right)^k[/tex]
And since x is independent of k, it can move out the front of the summation, so we have
[tex]x\sum_{k=0}^{n}{^n}C_k\left(x^2\right)^k1^{n-k}[/tex]
And now apply the formula to convert it into a binomial. And since you need to find f(1), take the derivative of both sides to get the expression for f(x).
Jun29-11, 05:07 AM   #31
Recognitions:
So now we have
If i convert it into binomial, i get
[tex]x.(x^2+1)^n[/tex]
I substitute the value 1 and i get
[tex]2^n[/tex]
But then how i would find out the derivative??
Do i have to first take the derivative and substitute the value 1?
Jun29-11, 05:50 AM   #32
Recognitions:
Good!
Yep!
Jun29-11, 07:52 AM   #33
Recognitions:
Yep, that's what I meant by
You're nearly there!
Jun29-11, 09:39 AM   #34
Recognitions:
Thanks!!
I think that this time i am right.
I took the derivative and found it to be
[tex]2nx(x^2+1)^{n-1}[/tex]
Now i substituted the value 1 and i got:-
[tex]2n.2^{n-1}[/tex]
Right...?
New Reply
Thread Tools
Similar Threads for: Converting Sigma notation....
Thread Forum Replies
Sigma Notation General Math 6
Sigma Notation Calculus & Beyond Homework 1
Sigma Notation Precalculus Mathematics Homework 4
Sigma notation Calculus & Beyond Homework 2
Sigma Notation Calculus & Beyond Homework 16
