Thread Closed
Why Is Acceleration Due To Gravity A Constant?
Share Thread Thread Tools
May25-09, 10:31 AM   #1
Mentor
This question has popped up many times. So here is an attempt to address it.
To answer this question at the elementary level, a number of assumption will be made, which will become obvious later on. Still, at this point, we will simply deal with objects with spherical symmetry and no complicated mass distribution. In other words, the mass of each object can be considered to be at their respective center of mass.
For two objects with masses, the gravitational force on mass 1 due to the gravitational force of mass 2 can be written as
[tex]F_{12} = \frac{Gm_1 m_2}{h^2}[/tex]
where [itex]m_1, m_2[/itex] are the masses of object 1 and 2 respectively, [itex]G[/itex] is the universal gravitational constant, and [itex]h[/itex] is the distance between the two masses. Of course, this equation is symmetric, and the force on 2 due to 1 also has the identical form.
Let [itex]m_1[/itex] be any mass and [itex]m_2 = M[/itex], the mass of the earth. Then the force on object 1 due to the earth is
[tex]F_{1M} = \frac{Gm_1 M}{h^2}[/tex]
But since this is the force on [itex]m_1[/itex], we can equate the dynamics of this object with
[tex]F_{1M} = \frac{Gm_1 M}{h^2} = m_1 a[/tex]
Simplifying, we get
[tex]\frac{GM}{h^2} = a[/tex]
which we define to be "g" at the surface of the earth, and is a constant if we always put different masses at the same location.
This means that no matter what [itex]m_1[/itex] is, the acceleration is always a constant g. It shows that the acceleration due to gravity is a constant.
Now, in deriving this, I've made an implicit assumption of one thing, that "M" really doesn't get affected much by [itex]m_1[/itex]. Recall that I said earlier that the gravitational force equation is symmetric. One can also talk about the force on the earth due to the mass [itex]m_1[/itex]. So that mass certainly exert a force on M. However, this is where we have to consider a little bit about the center of mass of the [itex]M + m_1[/itex] system.
[tex]r_{cm} = \frac{m_1 r_1 + MR}{m_1 + M}[/tex]
where [itex]r_1[/itex] is the location of the center of mass of [itex]m_1[/itex], and [itex]R[/itex] is the location of the center of mass of [itex]M[/itex], i.e. the earth. If we put our origin at the center of mass of the earth, then [itex]R = 0[/itex]. So let's do that. The center of mass location is then simplified to
[tex]r_{cm} = \frac{m_1 r_1}{m_1 + M}[/tex]
Now, for ordinary, terrestrial objects, the kind that Galileo (and you and I) would test in our intro physics classes, the mass of the object [itex]m_1[/itex] is much, much smaller than the mass of the earth, i.e. [itex]m_1 << M[/itex]. In that case, we can simplify the center of mass equation to
[tex]r_{cm} = \frac{m_1 r_1}{M}[/tex]
It means that the location of the center of mass of ordinary object + Earth system, for an object placed near or on the surface of the earth (i.e. [itex]r_1 ~ R_E[/itex]), depends predominately on the ratio of [itex]m_1/M[/itex].
An ordinary object weights in the range of kg. The earth weighs on the order of [itex]10^{24}[/itex] kg, and the radius of the earth is of the order of [itex]10^6[/itex]m.
If you do that computation, you'll get a very, very, small number for [itex]r_{cm}[/itex]. It means that the center of mass of this system is practically the same as the center of mass of the Earth, which is situated at r=0.
What I'm trying to show here is in this scenario, the earth does not make any significant motion due to the force exerted by [itex]m_1[/itex]. This means that for this case, it is perfectly fine to consider the earth as the fixed object, and only consider that it is the smaller mass that falls towards the earth. So when you consider that, then all the simplification that is done to allow us to deduce that the acceleration due to gravity of ALL objects falling on the surface of the earth to be a constant, independent of the mass of the object.
However, if we change that situation, i.e. if [itex]m_1[/itex] is now comparable, or even bigger, than [itex]M[/itex], then those simplifications will no longer be valid, and one will have to start from the very beginning to figure this out.
Zz.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Thread Closed
Thread Tools
Similar Threads for: Why Is Acceleration Due To Gravity A Constant?
Thread Forum Replies
Physics of a runner (Constant Acceleration/ constant velocity) Introductory Physics Homework 1
Why does gravity give a constant acceleration and centrifuge? General Physics 1
Why is Acceleration Due To Gravity Constant For All Bodies Irrespective Of Mass ? General Physics 39
Two particles and gravity; non-constant acceleration Classical Physics 22
