| Thread Closed |
What is Heat? |
Share Thread | Thread Tools |
| Feb3-08, 12:04 PM | #1 |
What is Heat?
Written by Hootenanny. Edited by berkeman and Kurdt. Feel free to contact me with any questions, comments or corrections.
What is Heat? One of the most frustrating misconceptions in Thermodynamics centres on the actual definition of heat. Many science/engineering students often refer to a body as to be possessing heat, but as we shall see, to do so is completely nonsensical. We start by examining the first law and defining each of it’s terms. The first law is simply a statement of the principle of conservation of energy and is often stated thus; [tex]\Delta U = Q + W[/tex] Where [itex]\Delta U[/itex] is the change in internal energy, Q is the heat added to the system and W is the work done on the system. So what do all these terms actually mean? Internal Energy We define the internal energy as the energy associated with the microscopic energies of system, that is with the energy associated with the random motion of the molecules within a system. So for a general fluid, the internal energy of a system is the sum of the translational kinetic energies, the rotational kinetic energies, the vibrational kinetic energies and the potential energies of all the molecules in that system. The internal energy of a system is often erroneously referred to as the heat of a system and we shall see why this is incorrect later. One important point to note here is that the internal energy is a state variable, that is, the change in internal energy between any two states is independent of the path taken.Work Well, if you're reading this I assume that you know the definition of work; in thermodynamics work is usually associated with a transfer of energy into or out of a system. An example of work specific to thermodynamics would be the application of a force to a piston, which would then compress the gas within the cylinder, thus doing work on the gas. Since work is being done on the gas the W term in our expression would be positive. If we assume that the walls of the cylinder are adiabatic (no heat transfer) then all the work done would be converted to internal energy. Suppose that after we have compressed the piston, we release it. Intuitively, we would expect the piston to recoil back, and this is exactly what happens; the gas expands and does [an equal amount of] work on the piston against atmospheric pressure. In this case, since it is the gas that is doing work, our W term would be negative.Heat So we have defined the internal energy of a system and we can quantify the work done on the system, but what about heat? First let us examine temperature. One useful definition of temperature is often called kinetic temperature and is derived from kinetic theory. Using kinetic theory the temperature of a system is taken to be a measure of the average translational kinetic energy associated with the random motion of the molecules with the system. It should be noted that although related to internal energy, temperature is not directly proportional to internal energy since internal energy also involves the rotational and vibrational kinetic energies and the potential energies of the constituent molecules.A note about Thermal Energy Some texts make use of the term "thermal energy" when discussing the "translational kinetic energy" of the molecules, I personally find that the term "thermal energy" only serves to confuse discussions further.Further Reading Thermal Physics, 2nd Edition, C.B.P. Finn Heat@Hyperphysics Internal Energy@Hyperphysics |
| Thread Closed |
| Thread Tools | |
Similar Threads for: What is Heat?
| Heat and Internal Energy and Heat and Temperature Change: Specific Heat Capacity | Advanced Physics Homework | 4 | ||
| Speed of Bullet with specific latent heat of fusion and heat capacity [HELP ME PLEASE | Advanced Physics Homework | 1 | ||
| [SOLVED] Quantity of Heat/Specific Heat Water+Iron | Introductory Physics Homework | 3 | ||
| Specific heat capacity, latent heat => ice water steam mixture | Introductory Physics Homework | 1 | ||
| Heat question!??the amount of heat gained or lost by a substance is equal to | Introductory Physics Homework | 8 | ||
