Finding volume bounded by paraboloid and cylinder
The discussion revolves around finding the volume bounded by a paraboloid defined by the equation z = 2x² + y² and a parabolic cylinder given by z = 4 - y². Participants are exploring the setup of a double integral to calculate this volume.
  • Participants discuss the potential need to convert to polar coordinates and the setup of the double integral. There is also a focus on determining the correct limits of integration based on the geometry of the problem.
Some participants have provided guidance on the interpretation of the equations and the limits of integration. There are ongoing questions regarding the correctness of the equations and the setup of the integral, with some confusion about the roles of the functions involved in the volume calculation.
There is uncertainty about whether the problem explicitly states that the solid is bounded by the coordinate planes, which affects the limits of integration. Participants are also grappling with the implications of negative volume results and the correct interpretation of the functions involved.
iqjump123
Find the volume bounded by the paraboloid z= 2x2+y2 and the cylinder z=4-y2. Diagram is included that shows the shapes overlaying one another, with coordinates at intersections. (Will be given if necessary)
double integral? function1-function2?
I saw from previous threads involving volumes, but still am lost when I try to do my own problem :\ Most paraboloid involving problems start by changing to polar coordinates- should I do it for this one? I know that at the end it will end up being a double integral, but I am not sure how to set it up.
physics forums have been a big help. Thanks!
Are your equations correct because z=4-y2 isn't the equation of a cylinder?
Yes, it is. z= 4- y2 is a parabola in the yz-plane and, extended infinitely in the x-direction, is a parabolic cylinder, though not, of course, a circular cylinder.
D'oh!
thanks for the reply- yes, just like what hallsofivy mentioned, the equations are correct.
At this point, I am still lost, however. Any other suggestions? Thanks!
As you mentioned in your original post, you want to calculate something like
[tex]V = \iint\limits_A [z_1(x,y)-z_2(x,y)]\,dy\,dx[/tex]
Why are the lower limits 0 for both x and y?
Well I assumed so, since the problem shape starts from the 0 position for all 3 coordinate systems. Is this approach not correct?
Does the original problem statement say the solid is bounded by the x=0, y=0, and z=0 planes or something equivalent? If it does, your limits look fine. I know the picture suggests this, but you never mentioned it in the original post, nor does it appear in your scan.
Hey guys, I know this is bringing up an old topic, but I wanted to inquire about something, as well as make sure I approached the final equation correctly.
To clear up the confusion from vela- yes, I am planning to go with the description saying that since they said to find the volume as indicated in the picture, my limits I set up was going to be from 0.
Therefore, I went ahead and said
∫∫(2x^2-y^2)-(4-y^2),y,0,√2-x^2),x,0,√2).
After evaluating this, I obtained -pi as my answer. the number makes sense, but the sign is wrong- negative volume is obviously impossible. When I reversed the two functions, I indeed get pi as the answer.
However, that doesn't make sense- wouldn't the z1 function have to be the function of the paraboloid, and the volume is a subtraction of the cylinder function z2 from z1?
Any clarification and a check to the final answer will be appreciated. Thanks guys!
Why do you think that would be the case?
