Two problems involving vector calculus-
The discussion revolves around two problems in vector calculus related to electrostatic potential and gravitational fields. The first problem involves finding the Laplacian of a potential function derived from a dipole, while the second problem focuses on calculating the curl of a gravitational field vector.
  • Mixed
  • Participants explore the nature of the potential function, questioning whether it is indeed a scalar field and how to express it in terms of Cartesian coordinates. There is discussion about the calculation of the Laplacian and the curl, with some participants expressing uncertainty about their results.
Some participants have provided clarifications regarding the nature of the functions involved, while others are attempting to derive expressions for the Laplacian and curl. There appears to be a productive exchange of ideas, with participants confirming each other's understanding and addressing potential misunderstandings.
There is mention of formatting issues with LaTeX and the potential need to separate the two problems for clarity. Participants are also considering the implications of their calculations and the definitions of the mathematical operations involved.
iqjump123
(Sorry for the confusing font- I tried to figure out using the latex reference to indicate a vector, but couldn't do it- please view the "superscripted" variable as a vector. Thanks)
A. The electrostatic potential at P arising form a dipole of unit strength at O, oriented in the direction of the unit vector n, is given by V= n[itex]\stackrel{OP\rightarrow}{}[/itex]/r^3, where r=OP and n coincides with the direction of the positive z axis. Find the value of
del^2V
B. Let F be the gravitational field of a mass oriented at the origin O and is expressed by,
F=c[itex]\stackrel{OA\rightarrow}{}[/itex]/r^3
where c is a constant and r is the distance OA.
Find the value of
Curl F
del^2V=d^2v/dx^2+d^2v/dy^2+d^2v/dz^2
the curl of a function involves the determinant of the matrix [i j k; deriv_x deriv_y deriv_z; f_x f_y f_z] (wrote in MATLAB form)
Sorry about putting two problems together- I figured since it is of similar origin, and the problem itself put it as if it is two parts to a problem. If it must be separated, that can be done.
A. I have managed to get to the point where I can get the expression of V= <0,0,1>[itex]\cdot[/itex]<x,y,z> /Magnitude of OP ^3.
Now do I just have to get the 2nd partial derivative of this function based on the three coordinate systems x y and z? I did it but looked pretty ugly (couldn't simplify), and wanted to make sure.
B. For this part, it looked like the function was:
F=c*<x,y,z>/(magnitude of OA)^3
I went through and calculated the curl of this function based on the formula above, but got 0. is this correct?
A) Potentials are not vector fields but scalar fields, are you saying that [itex]v=r^{-3}[/itex]? you know that [itex]r=\sqrt{x^{2}+y^{2}+z^{2}}[/itex], so now you have a function of x,y and z.
b)not done this calculation but curl is an indication of vorticity which is now much the field rotates (sort of...), if everything is coming from the centre...
hunt mat- thanks for your input!
a) I think my attempt at latex input failed miserably..
the function of v is
v= (n_unitvector*OP_vector)/r^3, and yes, r=(√x2+y2+z2)^3, so the final expression is
z/((√x2+y2+z2)^3), where x2=x^2- getting the del^2 of this function is what I need to do right?
Basically you're on the right tranck.
