Finding Equilibrium Forces: Are My Vector Calculations Correct?
  • Thread starter Thread starter IGeekbot
The discussion revolves around vector calculations related to forces in equilibrium, specifically in an introductory physics context. Participants are analyzing two problems involving multiple forces acting on an object and determining the resultant force required for equilibrium.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate the third force needed for equilibrium given two forces at specified angles and magnitudes. They also analyze a scenario with five forces to find a sixth force that maintains equilibrium. Some participants question the accuracy of the angles and magnitudes calculated, particularly in the second problem.
Participants have provided feedback on the calculations, with some confirming the first calculation while suggesting corrections for the second. There is an ongoing exploration of the correct angles and magnitudes, with multiple interpretations being discussed.
Participants express confusion regarding the teacher's explanations, indicating that the problem may involve misunderstandings or assumptions that need clarification. There is a mention of the importance of not rounding off during calculations, which may affect the results.
IGeekbot
Ok, I am in an intro to physics, so it is all trig based. But I just need to know if I did these vector problems right.
an object in equilibrium has 3 forces exerted on it. one at 90 degress is 33N, one at 60 degrees is 44N. Find the third.
Using the sine and cosine of those vectors, i got the thrid force to be 74.3N at 253 degrees. Is that right?
ANd the other one is: five forces act on an object, the first is 60N at 90 degrees, the second is 40N at o degrees, the third is 80N at 270 degrees, te fourth is 50N at 60 degrees, and the fifth is 40N at 180 degrees. what's the sixth force that puts the object in equilibrium?
I know that the 2 40N forces cancel, so i just found the vertical and horizontal force of the other three forces. Then after using more sin and cos laws, and
Fnet6^2 =Fnetx^2 + Fnety^2
I got the force should be 33.97N, and using tanget, it should be at 43 degrees.
Hi IGeekBot,
The first answer is correct. (Actually 74.4 N)
For the second, it should be at 223 degrees (180+43 degrees), watch the signs.
Since the sum of all forces is zero (equilibrium), you have:
[tex]F_6^2+F_{netx}^2+F_{nety}^2=0[/tex].
([itex]F_{netx}[/itex] and [itex]F_{nety}[/itex] do not include [itex]F_6[/itex])
The magnitude is 34.17 N. Be careful not to round off in intermediary stages of the calculation.
The first one is correct but for the seond one, i got 34.2 N at 223 degree from the positive x axis.
thanks, our teacher is a bit hazy sometimes, and it sems th ewhole group was lost on this.
10K
