What angle should movers set their truck ramp to minimize work?
Movers should set the ramp of their truck at an angle θ where tan θ equals the coefficient of kinetic friction (µ) to minimize the work required to move crates up the ramp with constant velocity. The work done is calculated as hmg(sin(θ) + µcos(θ)/cos(θ), where h is the fixed height of the truck bed. The solution involves balancing the forces of gravity and friction, leading to the conclusion that tan θ = µ is the optimal angle for efficiency.
  • Understanding of basic physics concepts, specifically forces and work.
  • Familiarity with trigonometric functions, particularly tangent.
  • Knowledge of kinetic friction and its coefficient (µ).
  • Ability to visualize and analyze right triangles in physics problems.
  • Study the relationship between forces and angles in inclined planes.
  • Learn about the derivation of work done against friction in physics.
  • Explore applications of trigonometry in real-world physics problems.
  • Investigate the implications of varying the coefficient of friction on ramp efficiency.
This discussion is beneficial for movers, logistics professionals, physics students, and anyone interested in optimizing mechanical work in moving scenarios.
tricky_tick
Movers want to set the ramp of their truck so that the work they do against the combination of gravity and friction is a minimum for crates moving up the ramp with constant velocity. µ is the coefficient of kinetic friction and θ is the angle between the ramp and the ground. For the work to be a minimum, they must choose:
a. tan θ = µ
b. tan θ = -µ
c. tan θ = -1/µ
d. tan θ = 1/µ
e. tan θ = 1 - µ
The obvious solution of setting the derivative of work equal to zero finds the maximum work. The problem asks for the minimum?
The word done is "Force*distance".
The force necessary to move an object (I'm assuming they are sliding it) is the component of weight along the ramp: mg sin(θ) (draw a picture and look at the right triangles!) plus the friction force: μ times the component of weight perpendicular to the ramp, mg cos(θ).
Force= mg sin(θ)+ mg μ cos(θ).
The distance is the length of the hypotenuse of the right triangle formed by the ramp: h/cos(θ) where h is the height of the ramp (which I am assuming is fixed: the height of the truck bed).
The work done is hmg(sin(θ)+ μcos(θ)/cos(θ).
What value of θ minimizes that?
The correct answer is a. tan θ = µ. This is because when the derivative of work is set to zero, it finds the maximum work. However, in this scenario, we want to minimize the work, which means we need to find the angle that will result in the least amount of work. By setting tan θ = µ, we are finding the angle that balances the force of gravity and friction, resulting in the minimum amount of work required to move the crates up the ramp with constant velocity. Therefore, movers should set their truck ramp at an angle where the tangent of the angle is equal to the coefficient of kinetic friction. This will minimize the work they have to do against gravity and friction, making their job more efficient.
  • · Replies 22 ·
9K
  • · Replies 56 ·
  • · Replies 68 ·
14K
