| New Reply |
Dynamic Friction between surfaces |
Share Thread | Thread Tools |
| Jul5-11, 07:45 AM | #1 |
We have a body V1, which is in contact over body V2 over a flat (i.e. planar) surface S. (The planar approximation can be considered a good one). Body V1 is moving, V2 is stationary. A normal force F exists between the bodies at surface S, acting in point P. This force acts along the unit normal vector N. The body V1 is moving with a body velocity V. Q: What is the dynamic friction force between V1 and V2? I think I found the solution, but I'd like a double check. Or a rebuttal with correct answer... 2. Relevant equations Ffriction = mu*F, acting opposed to the relative motion of the surfaces in contact. 3. The attempt at a solution 1. We find the relative speed in the plane S. As follows: N = unit normal surface vector in P. V = body velocity in point P. U = orthonormal projection of V on plane S. I think this is the speed the surfaces slide over each other. Is this correct? U = V - (V dot N)N 2. The components of U have dimension [m/s], but as the friction force is independent of speed, we need to normalise vector U. I.e. we only need to know which direction U has. U_ = U/norm(U) = [U_x,U_y,U_z] 3. The components of the friction force now become Ffriction,x = mu*|F|*U_x Ffriction,y = mu*|F|*U_y Ffriction,z = mu*|F|*U_z |
| New Reply |
| Tags |
| amontons' law, contact surfaces, coulomb, dynamic, friction |
| Thread Tools | |
Similar Threads for: Dynamic Friction between surfaces
| HELP!!!A dynamic question with friction | Introductory Physics Homework | 3 | ||
| friction between two surfaces | Introductory Physics Homework | 11 | ||
| Friction/Dynamic Equilibrium Help | Introductory Physics Homework | 4 | ||
| Static Friction Vs Dynamic/Kinetic Friction | Classical Physics | 8 | ||
