Why Does My Calculated Tangent Line Not Touch the Curve at the Given Point?
  • Context: Undergrad
  • Thread starter Thread starter danne89
The discussion revolves around the calculation of a tangent line to a curve defined by the function u = (6 + 2x^2)^3 at the point (1, 512). Participants are examining the derivative and the conditions under which the tangent line intersects the curve.
  • One participant expresses confusion about their calculations and requests corrections, particularly regarding the derivative and the tangent line.
  • Another participant points out a mistake in the algebraic manipulation involving the derivative, suggesting that the derivative should include an x^5 term.
  • A different participant emphasizes the need for clarity in the algebraic steps and highlights an error in the manipulation of terms.
  • One participant later provides a corrected derivative calculation, suggesting that the correct tangent line should be y = 768(x-1) + 512, indicating that the original tangent line does intersect the curve but is not tangent due to an incorrect derivative.
  • Another participant mentions that their graphing calculator does not yield the same results as those discussed, introducing further uncertainty.
Participants do not reach a consensus on the correct derivative or the nature of the tangent line. There are competing views on the calculations and the implications of the results.
There are unresolved issues regarding the accuracy of the derivative calculations and the algebraic manipulations involved. The discussion reflects varying levels of understanding and interpretation of the mathematical concepts.
Individuals interested in calculus, particularly those studying derivatives and tangent lines, may find the discussion relevant.
danne89
Hi. I can't get what I'm doing wrong here. If somebody points that out, I'm really gratefull.
[tex]u = (6 + 2x^2)^3[/tex]
[tex]d(u) = 3(6+2x^2)^2 d(6+2x^2)=3(6+2x^2)^2 d(6) + d(2x^2) <br /> = [3(6+2x^2)^2 * 0 + 4x]dx = 4xdx[/tex]
Then I want to draw a tangent on the point, which acctually lies on the line(!), (1, 512) to check the derivative.
[tex]l(x)=f'(a)(x-a)+b=4(x-1)+512=4x+508[/tex] Which don't intersect the curve at (1, 512)...
Please correct every misstake I've made. Yes, they could be many; I'm not so good on this stuff. :biggrin:
You've forgotten that there is a bracket around 6+2x^3 in the second line of the maths.
You've misspelled mistake too. And who said irony is dead?
Anyway, du/dx is not 4x as should be obvious to you (u if you multiplied it out would have an x^6 term in it and hence du/dx must have an x^5 term in it.
Hmm. I'm sorry, but I don't get it. Can you please be a little more specific. This stuff is doing me crazy!
Go through the second line of maths look how you write, in effect:
A(B+C) = AB + C.
when you go "across" the second equals sign in the line, ie from
[tex](6+2x^2)^2 d(6+2x^2)=3(6+2x^2)^2 d(6) + d(2x^2)[/tex]
they aren't equal. Your algebraic manipulation is wrong.
Ahh! Thanks! That should I've noticed...
[tex]d(y)=3[(x^2+5)^2][d(x^2+5)]=3[(x^2+5)^2][d(x^2)+d(5)] = 3[(x^2+5)^2]2x=6x(x^2+5)^2[/tex]
[tex]d(u) = 3(6+2x^2)^2 d(6+2x^2)=3(6+2x^2)^2 d(6) + d(2x^2)[/tex]
Should be
[tex]d(u)= 3(6+2x^2)^2 d(6+2x^2)= 3(6+2x^2)^2[d(6)+ d(2x^2)][/tex]
[tex]d(u)= 3(6+2x^2)^2[0+ 4xdx]= 12x(6+2x^2)^2dx[/tex].
What you give: l(x)= 4x+ 508 certainly does intersect the curve at (1, 512): l(1)= 4+ 508= 512. It just isn't tangent to the curve because your f'(1) is incorrect.
When x= 1, du/dx= 12(1)(8)2= 768.
The tangent line should be y= 768(x-1)+ 512= 768x- 256.
That works nicely. (Aren't graphing calculators wonderful!)
Mine doesn't give me that though.
