| New Reply |
Which planet in this solar system would be most appropriate to terraform? |
Share Thread | Thread Tools |
| Mar17-12, 06:54 PM | #35 |
Which planet in this solar system would be most appropriate to terraform?Edit: I see where you are going after re-reading. You are arguing about getting the entire planet in the penumbra, while I was arguing about getting the entire planet into the Umbra. |
| Mar17-12, 08:00 PM | #36 |
| Mar18-12, 07:15 AM | #37 |
Wouldn't it be kind of difficult to keep a large object stationary relative to a planet if it isn't located in one of the Sun-Planet lagrange points?
| Mar18-12, 09:59 AM | #38 |
its not really stationery, it has to constantly move as both planet and the sun are moving, and it cant be in orbit as then it would need to be to big to be possible (about planet size) maybe it would be easier to create millions of orbiting satellites with huge mirrors+solarpanels, powered my solar energy and all networked so they wont collide but i dont know about this plan, because the ground pressure is still 95 x higher then earth, even if the temperature drops, to much "air" makes also takeoff and landing more difficult and converting all that CO2 in to O would take how knows how many 100's or 1000's of years, also cant really convert it all there is just to much of it, lets say we do 50% oxygen 50% CO2 that would make the planet very flammable, and pressure would be still to high (estimating 60-70x earth), as there is no hydrogen O would not turn in to water, at least not much of it |
| Mar18-12, 11:15 AM | #39 |
Yes, the further the Moon, the larger the penumbra, however, this also decreases the "deepness" of the shadow. The amount of light striking each square meter would go up. This increase of Light level in the penumbra increases faster than the surface area tha the penumbra covers does. Moving the moon further away can only increase the total sunlight striking the Earth. |
| Aug20-12, 12:50 PM | #40 |
Because of this, I believe that Venus is a poor candidate for terraforming, as it will eventually be subject to the increasing luminosity of the sun as it finishes the main sequence. Earth, too, will be in danger, so it would be wise to select a planet that has a good chance of escaping the red giant phase if we really do intend to survive and prosper indefinitely. Mars is quite appropriate for several reasons. 1) Reasonably similar gravity to earth's (0.376g) 2) Conveniently reduced escape velocity for transfer of materials to and from orbit 3) High oxygen content (in iron oxide) 4) Bearable temperature & pressure ranges 5) Proximity (~7 minute delay in communications, regular resupply from earth feasible) 6) Familiarity - we've already started exploring it and have the technology today for landing. The easiest way to go about the terraformation would be to send over a probe full of our favorite lichen, moss, and (genetically modified?) microbes that would start clambering over the surface, devouring iron oxide and releasing heat & H20. Perhaps we can one day slingshot magnetic materials around it at ridiculous speeds to jump-start the core and provide a magnetosphere to boot... if not, we'll find a way to generate the shielding we need. Eachus said some very interesting things about starting in Martian valleys. I think that process could start within a year if we applied ourselves. Mars One estimates the cost of sending 4 crewmembers to Mars permanently to be $6 billion, about as much as the U.S. spends on defense every 2-3 days in 2012 money - so the resources are there if we can find common ground for cooperation. Don't forget, the asteroid belt is right next door to Mars. Once we get a foothold on and around the red planet, it will be that much easier to access those resources and relieve scarcity even back home. The moons of the gas giants will be great resources for a network of space stations throughout the solar system, but terraformation will be much less feasible owing to the gravitational stripping of their atmospheres caused by the planets they orbit. With the limitations we experience here, I can't help looking past earth and imagining an interstellar future for humankind. Our homeworld will always be sacred, but future lies among the stars. |
| Aug20-12, 02:45 PM | #41 |
Mentor
that really doesn't seem bearable to anything but extremophiles. Sure there may be areas where the temperature peaks to above zero but that does not a healthy environment make.That's not to mention the hellishly complex task of constructing an ecosystem from scratch on a world with different characteristics. Ecosystems are not modular systems you can just build up species by species, they are (at minimum) complex, dynamic trophic webs that rely on the interaction of thousands of species to remain somewhat sustainable. |
| Aug20-12, 03:47 PM | #42 |
Now that's a prime example of "chickity-check yourself before you wrickity-wreck yourself." Thanks for the warm welcome, I look forward to improving my phys-fu.
I only speak in relative terms of the "reasonable" attributes of Mars. It's not like we have a hard day/night split like on the moon, and the gravity is neither crushing nor negligible. You're absolutely correct about what you've said, though. I'll have to be better prepared next time before I go around declaring my opinions. |
| Aug20-12, 05:07 PM | #43 |
I still see Mars as an attractive option for permanent settling. It would be within the range of current technology (though perhaps not within political sentiment for funding) to construct a series of probes that attach to comets with favorable intersect orbits with mars. Boosting up to comet speed is energy intensive but small adjustments using solar powered ion thrusters or plutonium reactors over a reasonably long period of time would do the trick to have the comet captured by Mars and eventually impact. Say, aren't the poles of Mars covered with frozen CO2 and H20? Wonder how much of an atmosphere we could get out of those with a few 1000-megaton equivalent impacts. |
| Aug20-12, 05:14 PM | #44 |
Also, a nice sobering read for the difficulties of humans "making it in space"
http://physics.ucsd.edu/do-the-math/...why-not-space/ (somewhat related to the grand vision of terraforming) |
| Aug20-12, 05:17 PM | #45 |
Mentor
As I said above I'm by no means opposed to the idea that people might one day live in space in significant numbers but I don't see it happening any time soon and I don't see any reason to do it other than for the panaché. |
| Aug20-12, 06:15 PM | #46 |
It is my belief that no terraforming project will be sustainable if it is based solely in that name of "science" and done under the auspices of some tumorous government entity like NASA. There has to be some economic benefit that will attract private sector entrepreneurs into space, otherwise the project will be a huge money-pit with nothing to show except a few dirt samples. I'm not saying there are no economically attractive attributes of outer space (read Lewis' book Mining the Sky), I'm saying it's a waste to do it in the name of some government bureaucracy.
| Aug21-12, 01:20 AM | #47 |
Mentor
| Aug21-12, 04:41 AM | #48 |
One very interesting thing to read the *entire* "let's go to the moon" speech http://www.jfklibrary.org/Research/R...y-25-1961.aspx Space was item 9, and the famous quote "I believe that this nation..." has been taken wildly out of context. If you read the whole speech it was clearly, "I think that we should go to the moon, but we need to talk about this, and if we decide not to then lets give up right now rather than go half way." |
| Aug21-12, 04:46 AM | #49 |
| Aug21-12, 04:53 AM | #50 |
Mentor
The ability to destroy in most cases is far easier than the ability to maintain or build. |
| Aug21-12, 06:43 AM | #51 |
| New Reply |
| Tags |
| terraforming |
| Thread Tools | |
Similar Threads for: Which planet in this solar system would be most appropriate to terraform?
| Could a Solar Flare destroy life on our planet? | General Astronomy | 27 | ||
| What color is the sky on extra-solar planet? | General Physics | 3 | ||
| binary planet system | Advanced Physics Homework | 8 | ||
| How would the solar system capture an extra solar planet ?? | General Astronomy | 14 | ||
| Astronomers photograph extra-solar planet | General Astronomy | 4 | ||
