Differential equation in fortran
The discussion focuses on implementing the fourth-order Runge-Kutta algorithm in Fortran for solving a system of differential equations with imaginary components. The equations provided are x'=(i)y *exp(iwt) and y'=(i)x*exp(iwt), where 'i' represents the imaginary unit and 'w' is a constant. The initial approach of defining x and y as real variables led to errors due to the complex nature of the equations. A recommended solution involves defining all variables, including x and y, as complex and utilizing the properties of complex exponentials to reformulate the equations into a system of real variables.
  • Understanding of complex numbers and their representation in programming.
  • Familiarity with the fourth-order Runge-Kutta algorithm for numerical integration.
  • Proficiency in Fortran programming language, particularly with complex data types.
  • Knowledge of differential equations and their numerical solutions.
  • Learn how to define and manipulate complex numbers in Fortran.
  • Study the implementation of the fourth-order Runge-Kutta method for complex differential equations.
  • Explore the conversion of complex differential equations into systems of real equations.
  • Investigate the use of complex exponentials and their properties in numerical computations.
Mathematicians, physicists, and engineers involved in numerical simulations, particularly those working with complex differential equations in Fortran.
nirajaryal
I need to do numerical computation by fourth order Runge Kutta Algorithm
in fortran. But I stuck in programming because the differential
equation contains imaginary part.
Take for e.g. the set of diff.equation are
x'=(i)y *exp(iwt) ;where i is imaginary no. and w is constant!
y'=(i)x*exp(iwt)
I tried to define complex function f and g as
f=(0,y *exp(iwt))
g=(0,x *exp(iwt))
and i defined x and y as real (because the argument of the complex
no.has to be real,right?/otherwise it doesn't accept)
But after every iteration,the x and y becomes real as
x=x0+some linear combination of the function f(which is complex)//and
real +complex gives complex no. and hence shows error!
So i unable to proceed further! So how should I proceed?
Technology news on Phys.org
y'=(i)x*exp(iwt)
f=(0,y *exp(iwt))
g=(0,x *exp(iwt))
That is wrong, because your definitions of f and g are not the same as your differential equation.
Try something like this:
define ZI as a complex constant = (0.0, 1.0)
Make X, Y, F and G all complex
and then do
F = ZI * X * exp(ZI * W * T)
Alternatively, you could convert this to a set of equations in 4 real variables, the real and imaginary parts of x and y. Since exp(iwt) = cos wt + i sin wt
If you write x = xr + i xi and y = yr + i yi, where xr, xi, yr, yi are real, then
i * y *exp(iwt) = (i yr - yi) (cos wt + i sin wt)
= -yi cos wt + yr sin wt + i (yr cos wt - yi sin wt)
So you would have
xr' = -yi cos wt + yr sin wt
xi' = yr cos wt - yi sin wt
and similar equations for yr' and yi'
  • · Replies 59 ·
12K
9K
