How Do Oxygen Molecule Quantities Differ in Two Physics Problems?
  • Thread starter Thread starter jaidon
    Molecules Oxygen
The discussion focuses on calculating the number of oxygen molecules required to achieve a pressure of 1.00 atm in a cubical vessel with sides of 0.10m at 300K. The first calculation utilizes the formula P = (2/3)(mN/V)vrms2 to relate pressure to the mean square velocity, while the second calculation employs the ideal gas law PV = (N/NA)RT to determine the total number of molecules. The conclusion indicates that the number of molecules in the second scenario is three times that of the first due to the differences in the conditions being analyzed.
  • Understanding of the ideal gas law (PV = nRT)
  • Familiarity with root mean square speed (vrms)
  • Knowledge of Avogadro's number (NA)
  • Basic principles of kinetic theory of gases
  • Study the derivation of the ideal gas law and its applications
  • Learn about kinetic theory and its implications for gas behavior
  • Explore the concept of root mean square speed in detail
  • Investigate the equipartition of energy principle in thermodynamics
Students in physics, particularly those studying thermodynamics and gas laws, as well as educators seeking to clarify concepts related to pressure and molecular quantities in gases.
jaidon
i have a multi-part question which is fine except for two areas.
1) how many oxygen molecules traveling at this speed (i already have the speed calculated) are necessary to produce an average pressure of 1.00 atm?
2) calculate the number of oxygen molecules that are actually contained in a vessel of this size (cubical with sides of 0.10m) at 300K and atmospheric pressure.
the problem is that i don't understand the difference between the two questions. i wanted to use PV=2/3NKav for one but i don't know which one or what to use for the other. It also says that the answer to 2 should be 3 times the size of 1. I find this very confusing. Could anyone try and explain the difference to me? Thanks
The pressure is related to the mean square velocity as,
[tex]P = \frac{2}{3}\frac{mN}{V}v_{rms}^2[/tex]
If the speed you're using is the root mean square speed, its okay to use this relationship. In deriving it, you use the equipartition of energy principle to give equal degrees of freedom along the 3 mutually perpendicular axes and you arrive at the expression involving root mean square speed.
For the second part you would use
[tex]PV = \frac{N}{N_{A}}RT[/tex] and solve for N.
The second part is pretty straightforward. All you have to do is write the number of moles in the ideal gas equation as the ratio of the number of molecules to the avogadro number.
Hope that helps...
Cheers
Vivek
i'm still not sure what the difference in the situations is. what is going on that would make the second question three times larger than the first?
