Method of Characteristics for Solving Non-Divergent Differential Equations
  • Thread starter Thread starter gtfitzpatrick
    Method
The discussion focuses on applying the method of characteristics to solve the non-divergent differential equation given by x(∂u/∂x) + y(∂u/∂y) = -x²u³ with the initial condition u(x,1) = x. The initial attempt involved separating variables and integrating, leading to the equation dy/dx = y/x. However, participants pointed out that the method of characteristics is inappropriate for this case due to the non-zero divergence of u. A recommendation was made to use a change of variables to simplify the equation and reduce it to a single variable for a more effective solution.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with the method of characteristics
  • Knowledge of integration techniques and separation of variables
  • Basic concepts of divergence in vector calculus
  • Research the method of characteristics for first-order PDEs
  • Learn about change of variables techniques in differential equations
  • Study the implications of divergence in vector fields
  • Explore examples of solving non-divergent differential equations
Mathematics students, researchers in applied mathematics, and professionals dealing with differential equations, particularly those interested in advanced methods for solving PDEs.
gtfitzpatrick
x([itex]\partial u / \partial x[/itex]) + y([itex]\partial u / \partial y[/itex]) = -[itex]x^2u^3[/itex]where u(x,1) = x for -[itex]\infty[/itex] < x < [itex]\infty[/itex]
dy/dx = y/x
= ln(y)=ln(x)+k k=constant of integration
=[tex]y = x + e^K[/tex]
=y=x+k
along this characteristic
[tex]du/dx = -(x^2u^3)/x[/tex]
= [tex]-xu^3[/tex]
= [tex]1/(2u^2) = ln(x) + F(K)[/tex]
not sure where to go from here...
should i simplify more for u and swap in k=y-x then use the conditions?
You're using the wrong method here, it seems. The method of characteristics you've set up is tailored to the case where the divergence of the function u is zero. Here it is not. Try something like a change of variables, to eliminate (say) y from your equation and reduce it to one variable.
  • · Replies 18 ·
