How Does the Binomial Theorem Explain the Middle Term of (a+b)^4?
  • Thread starter Thread starter morbello
The discussion centers on the application of the Binomial Theorem to derive the middle term of the expression (a+b)4. The middle term, specifically 6a2b2, is identified through the expansion of the expression using the theorem. The Binomial Theorem provides a systematic way to expand expressions of the form (a+b)n, where the coefficients can be determined using binomial coefficients. The participants emphasize the importance of correctly interpreting the expression and applying the theorem to find specific terms.
  • Understanding of the Binomial Theorem
  • Familiarity with binomial coefficients
  • Basic algebraic manipulation skills
  • Ability to expand polynomial expressions
  • Study the derivation and application of the Binomial Theorem
  • Learn how to calculate binomial coefficients using Pascal's Triangle
  • Practice expanding polynomials using the Binomial Theorem with different values of n
  • Explore applications of the Binomial Theorem in probability and combinatorics
Students, educators, and anyone interested in mastering algebraic expansions and the Binomial Theorem for mathematical applications.
morbello
Could you tell me how this equation works and how to get to the answer.ive done it before and am still stuck on how 6a^2b^2 is in the middle
(a+b)^4
a^4 4a^3b
giving the 6A^2B^2 in the middle is it if you have a exponent out side the brackets it works down to ^2 as it would look like or is there an easyer way to say how to do this equation.
is there a formula to work it out.
(a+b)^4
First, I should point out that there is no equals sign to be seen anywhere, so you haven't shown us an equation. What you show is an expression.
Are you wanting to express (a+b)4 without brackets?
If so, then it's straightforward. You need a large sheet of paper, a sharp pencil, and an eraser.
(a+b)4 can be written out as (a+b) (a+b) (a+b) (a+b)
You then work this out in stages, or however you like, e.g., you could do it as:
(a2 + 2ab + b2)(a2 + 2ab + b2)
Now, multiply this out, one term at a time, and eventually collect terms. There is a lot of writing to do, but each small step is easy. First, everything contained in the second brackets is multiplied by a2, then everything in the second brackets is multiplied by 2ab, and so forth.
morbello said:
a^4 4a^3b
Looks like some terms (and operation symbols) are missing.
Yes. Look up the Binomial Theorem.
  • · Replies 18 ·
