Register to reply
Henderson Hasselbalch equation question
by elegysix
Tags: equation, hasselbalch, henderson
Share this thread:
elegysix
#1
Jul14-11, 12:27 PM
P: 316
We are given Ka = 1.8x10^-5 for acetic acid.
We have a weak acid and a strong base, HC2H3O2 (acetic acid) and NaOH (sodium hydroxide).
We have 5 mL of acid and 5 mL of base, both at .1M, and 30mL of H2O
If nothing else, how do you know when to use the Henderson-Hasselbalch equation?
2. Relevant equations
HH eqn : pH=pKa + log(X-/HX)
3. The attempt at a solution
If we have the situation
HX + H2O <--Ka--> (H30+) + (X-)
NaOH + H2O <-> (Na+) + (OH-) + H2O
(Na+) + (OH-) + (H30+) + (X-) + <-> 2*H20 + (X-) + (Na+)
Na+ has negligible effects on pH
HX + NaOH + H2O <-> 2*H2O + (X-)
If I want to find the pH of this solution, can I use the HH equation?
if so, the Ka that I'm given is for dissociation of HX in water - not the dissocation of HX in a solution containing a base. Can I still use that Ka in the HH eqn? if I can, why does that work?
pH = pKa + log ( X-/HX)
pH = -log(1.8x10^-5) + log (X-/HX)
initial concentrations: [HX], [NaOH] = 5mL*.1M/40mL =1/80 M
------------|[HX] ----|[NaOH]------||[X-]|
Initial)------|1/80-----|1/80--------||0---|
Change)----|(-u)----- |(-u)-------- ||+u--|
Equilibrium)-|(1/80-u)--|(1/80-u)----||+u--|
using Ka = (aq)products/ (aq)reactants, Ka = 1.8x10^-5, then 1.8x10^-5= u/(1/80-u)^2 -> say we find u= B
then is the pH given by
pH= pKa + log( X-/HX ) ?
pH = -log(1.8x10^-5) + log( B/(1/80-B) ) ?
What I suspect is wrong:
1) using the 1.8x10^-5 as the Ka in the HH eqn. I feel like this value would be different since we are putting the acid into a basic solution and not water.
2) using the 1.8x10^-5 as the Ka to find the change in concentration, u, in the I.C.E. table, for the same reason.
are these things wrong? what should I do?
thanks for any help guys
Phys.Org News Partner Science news on Phys.org
Fungus deadly to AIDS patients found to grow on trees
Canola genome sequence reveals evolutionary 'love triangle'
Scientists uncover clues to role of magnetism in iron-based superconductors
Register to reply
Related Discussions
Henderson-Hasselbalch equation Biology, Chemistry & Other Homework 3
Henderson-Hasselbalch equation Biology, Chemistry & Other Homework 6
Using Henderson-Hasselbach equation? Biology, Chemistry & Other Homework 15
Protein pH titration (Henderson-Hasselbalch) Biology, Chemistry & Other Homework 5
Henderson Hasselbalch equation! Where did I go wrong? Biology, Chemistry & Other Homework 3
