| New Reply |
Stiffness and hardness , strength and toughness |
Share Thread |
| Jul15-11, 03:20 AM | #1 |
Hello
can someone please tell me the difference between stiffness and hardness and between strength and toughness? thanks |
| PhysOrg.com |
engineering news on PhysOrg.com >> Multiview 3-D photography made simple >> Giant 3-D printed bugs shed light on insect anatomy >> A microphone that listens with light |
| Jul15-11, 03:27 PM | #2 |
Hello Cosmossos!
![]() ![]() Toughness (of a material) is energy per volume just before failure (in J/m3). But isn't energy = force times displacement, so energy per volume = force times displacement per volume = force times area? 1 J/m3 = 1 N/m2 ? ![]() Yeees, but energy is the integral of force times displacement, so the total energy (per volume) absorbed by the material before failure depends on the shape of the force-displacement (per volume) curve (more usually called the strain-stress curve) (strain = ∫ displacement per thickness = ∫ displacement times area per volume,For good examples of stress-strain curves, see this diagram on the page http://www.etomica.org/app/modules/s...ckground1.html … the linear part is the elastic region, where energy per volume is proportional to force per area, the non-linear (curved) part is the plastic region (the ductile region, if we're talking about tension), and it ends at failure … the total energy absorbed by the material (the area under the graph) depends on the shape of that non-linear part. (it curves down at the end because of the difference between apparent stress and actual stress … the actual stress-strain curve keeps going up … see this diagram at http://en.wikipedia.org/wiki/Stress–strain_curve)Brittle materials are strong but not tough … they fail almost immediately after the end of the linear part. ![]() Yield strength (of a material) is force per area at the top of the linear part. |
| Jul16-11, 07:12 AM | #3 |
Stiffness and hardness are resistance to elastic (temporary) and plastic (permanent) deformation, respectively.
| Jul17-11, 11:37 AM | #4 |
thank you very much !!!
| New Reply |
| Tags |
| stress-strain, toughness |
Similar discussions for: Stiffness and hardness , strength and toughness
| Fracture Toughness and Strength | Materials & Chemical Engineering | 1 | ||
| Limit to the strength, the hardness, and the density of a material? | General Physics | 6 | ||
| High Strength Steel with Corrosion Resistance and High Toughness | Materials & Chemical Engineering | 7 | ||
| What's the difference between toughness and strength? | Materials & Chemical Engineering | 3 | ||
| What's the difference between toughness and strength? | General Engineering | 4 | ||
