| New Reply |
Switching/circuit breaker circuits |
Share Thread | Thread Tools |
| Jul16-11, 10:09 AM | #1 |
Hi guys, Im Thava. Im working in optical communication. Currently I want to design a circuit to turn of couple of inputs to my laser.
Say I have a supply of 5V to two pins of the laser, anode and cathode (pin 1 and pin 2). And then a bias current to another pin (pin 3). At some interval of time, I want to switch off the 5 V input to cathode and of course anode is grounded; also switch off the input bias current. The switching off time should be in about 100 kHz, and it should be controllable. It should be in a way that, if I supply a pulse with pulsewidth of 100 kHz, it should switch off exactly at the falling edge of the 100 kHz. Is it possible? And the switching time should vary, like I can always change the switching time. I just need some suggestions, ideas and discussion. I have so many ideas on doing it, but cant choose a proper way, so I just need some guidance. It will be much appreciated!! Thank you. |
| Jul16-11, 12:33 PM | #2 |
The simplest type of switch just uses a single MOSFET - when you apply a gate voltage above the threshold, it has a very small resistance between source and drain. When you apply zero volts, it has a higher resistance. One can then build more complex circuits uses multiple transistors to give a lower on-resistance and higher off-resistance, but at the cost of a slower response. |
| Jul18-11, 02:40 AM | #3 |
Thanks very much for your reply!
Current rating would be from 40 mA to 150 mA. Do you have any reference circuits or model that will feed into this applications? I need to a circuit to start with. Thank you. |
| New Reply |
| Thread Tools | |
Similar Threads for: Switching/circuit breaker circuits
| Circuit breaker problem | Electrical Engineering | 11 | ||
| Circuit Breaker | Electrical Engineering | 1 | ||
| Circuit Breaker Sizing | Electrical Engineering | 3 | ||
| Switching power circuits with small control circuits | Electrical Engineering | 14 | ||
