Solving Gas Work: Va, Vb, Pa, Pb
  • Context: Undergrad
  • Thread starter Thread starter perplexabot
    Gas Work
The discussion revolves around calculating the work done by a gas during a transition from state a to state b on a pressure-volume (pV) diagram. Participants explore different methods of integration and the implications of linear relationships between pressure and volume, while addressing the assumptions involved in their calculations.
  • One participant proposes using the integral of pressure with respect to volume to calculate work, suggesting a linear relationship for pressure.
  • Several participants challenge the assumption that the pressure-volume relationship can be expressed as p = kV, arguing that it does not pass through the origin.
  • Another participant suggests that the integrating constant is not relevant in definite integrals, which leads to confusion about its necessity.
  • A participant recalculates the work done using the correct linear equation for pressure and arrives at the expected answer, indicating that the initial method was flawed.
  • There is a discussion about the appropriateness of using the area of a trapezium to find the work done, with some participants advocating for this simpler method over integration.
  • One participant notes that Boyle's Law applies under specific conditions and that the graph cannot extend to the origin without violating physical principles.
Participants do not reach a consensus on the correct formulation of the pressure-volume relationship. There are competing views regarding the validity of the integration method versus the area method, and the discussion remains unresolved on certain technical points.
Participants express uncertainty about the assumptions made in their calculations, particularly regarding the linear relationship between pressure and volume and the implications of integrating constants in definite integrals.
This discussion may be useful for those interested in thermodynamics, particularly in understanding the calculations of work done by gases and the implications of different mathematical approaches in physics.
perplexabot
Hi all. Trying to find work done for a gas... Here is the question:
A quantity of air is taken from state a to state b along a path that is a straight line in the pv-diagram (figure is attached). If Va = 0.07, Vb = .11, Pa = 100,000 , Pb = 140,000. What is the work W done by the gas in this process? Assume that the gas may be treated as ideal.
Ok i know the area under the graph is work. But instead of doing it that way can i use this way?:
W = (integral of) p dV
and since p is changing linearly: p = mV + b where b = 0 and m = (Pb - Pa)/(Vb - Va) = k
so p = k* V
substituting that back into the Work equation i get:
W = (integral of) k * V dV
=> W = k * (integral of ) V dV
=> W = k/2 (Vb2 - Va2)
ok so after all this i end up with 3600 J which is wrong (actual answer is 4800). Can any1 tell me what I'm doing wrong? or why this technique doesn't work?
once again i know u can just find the area of the graph, but i want to know why this way is wrong..
Thanks all.
Where has "So p = k.V" come from? It implies that the line goes through the origin, which it doesn't. I think something has gone wrong with your algebra, though this started correctly.
p = k * V where k is just m or the slope ( (Pb - Pa)/(Vb - Va) ).
and if the figure is scaled correctly, if you continue the line, it will pass through the origin.
could it be that i didn't take into account the integrating constant?
I don't think the line does go through the origin. PA/VA doesn't equal PB/VB.
With a definite integral there isn't and "integrating constant" is there? The difference between values at the limits will cancel it out.
Are you sure that the "actual answer" is correct? I can't be bothered to do the substitution sums but your algebra looks fine. If you have put the right numbers into the result of your algebra / integration, then your answer should be right, I think.
I think your way of working out the area is using the 'wrong' trapesium. If you use the one with the p along the base, you get the same answer as your integration method. (i.e. swap your axes)
I must say, I started off thinking Boyle's Law and got totally confused until I re-read the OP!
To reiterate: the linear relationship between P and V cannot be written as P = kV, for the reason I've given. This needs sorting out before proceeding to the integration.
hey... alright so your saying p =mV + b where b is NOT equal to zero because the line does NOT pass though the origin...
pa = m*Va + b
pa = 100,000
Va = .07
m = (pb - pa) / (Vb - Va) = (140,000 - 100,000)/(.11 - .07)
= 40,000/.04 = 1 *106
b = pa - m*Va = 100,000 - (106 * .07) = 30,000
so p = kV + b
=> p = 106V + 30,000
using the above equation for p, I subbed it back into the Work equation and solved... I got exactly 4800 (which is the correct answer). So as you said Philip, the line does NOT pass through the origin.. Thanks for your help...
Well done for your persistence! I expect, though, that having satisfied yourself that the integration method works, you'll use the simple 'area of trapezium' method if you meet straight lines again in the p, V context!
ok thanks for clearing that out. i didn't know that only indefinite integrals had integrating constants. that actually helps a lot. thanks
yes, i will be using the area method from now on. i just wanted to see if i can do it otherwise.. thanks for the help...
I think that you, as I did at first, have missed the point and not read the question fully. You can make p proportional to v if you like over a limited range. Boyle's Law (pv=a constant) only holds for constant temperature. You can ' insist' on any relationship as long as you are prepared to add or take away the appropriate amount of internal energy.
That graph could not ever go to the origin - it wouldn't hold to a straight line without ridiculous / impossible imposed conditions.
Yes but you need to choose the right area;one that integrates p dv and not v dp. In the same way that Work done = distance moved times force and not force change times distance.
I think that who missed the point and who didn't is clear from the sequence of responses.
  • · Replies 31 ·
  • · Replies 27 ·
10K
