New Reply
MATLAB - Image Processing - Douday's rabbit fractal
Share Thread Thread Tools
Aug5-11, 10:16 PM   #52
Recognitions:
Quote by mheslep View Post
For anyone interested, here's the same code in Python
Thanks for the info mheslep. Very interesting, I'll have to take a look at those python modules. In the past I know it's been common to translate matlab to fortran for faster execution. I have actually translated the above code in Fortran and it is indeed several times faster than the matlab code (though i did it more as a sanity check in this case) BTW. Also take a look at gnu-octave for an excellent freeware matlab clone.
Back to the question of why greenprint is getting unexpected results. Would you be able to make a quick test for us with that python code to test the conjecture that the direction of the inequality in a = np.where(np.abs(z)<sqrt5) should cause either a multi-level or a
two-level map to be produced.
In particular could you please test if replacing the above line with, a = np.where(np.abs(z)>sqrt5), causes your program to produce only a two level map (and a corresponding monochrome image).
Aug6-11, 08:35 PM   #53
Recognitions:
Gold Membership Gold Member
Quote by uart View Post
Sure. The orginal, abs(z)<sqrt(5):
and the almost(?) monochrome image obtained from
abs(z)>sqrt(5):
Aug7-11, 06:51 AM   #54
Recognitions:
abs(z)>sqrt(5):
Arrh. That's exactly the image that Greenprint is getting and that we're having difficulty explaining. You see that's actually far from a two level map, there are lots of different shades and colors in that image, which implies that the map "matrix" must contain may different numbers, but I can only explain two of them!
Anyway I'm currently installing those python packages and am just about to try and reproduce you code. Hopefully I'll be able to get to the bottom of it once I see the results for myself. :)
Aug7-11, 07:20 AM   #55
Recognitions:
Mystery solved !!!
Ok once I got the python code running it didn't take long to figure out what was happening. In the end it turned out to be fairly simple, the gnu-Octave I'm using thinks infinity > sqrt(5), as do I, but Matlab and Python think otherwise.
Well actually it's the way the respective programs handle numerical overflow. There are regions on the map that begin with |z|>2, so not surprisingly when you keep repetitively squaring this you soon get a numerical overflow, (((2^2)^2)^2)^…, it only takes about 10 iterations to exceed even a double precision floating point capability. When this happens Octave returns "+inf" for the absolute value, while matlab and python return "nan" (not a number).
So that's it. All the lovely shading that Greenprint (and his matlab textbook) have been getting in their images have been purely the result of bad programming and a glitch in the way the matlab handles numerical overflow.
Aug7-11, 06:40 PM   #56
Recognitions:
Ah, thanks.
Numpy has a hack around for the overflow that (efficiently) forces NaN's to zeros:
http://www.scipy.org/Numpy_Example_L...21e560ab316ef3
So that
Code:
    z = z**2 + c
    z = np.nan_to_num(z)
    map[a] = k
produces the attached image as you would expect
Aug11-11, 03:42 PM   #57
Recognitions:
Python-Numpy comparison with Matlab:
http://www.scipy.org/NumPy_for_Matlab_Users
New Reply
Thread Tools
Similar Threads for: MATLAB - Image Processing - Douday's rabbit fractal
Thread Forum Replies
Image Processing Science Textbook Discussion 2
Image Processing Programming & Comp Sci 4
Matlab Image Processing Help (Image Segmentation) Math & Science Software 1
Matlab Image Processing. Math & Science Software 1
image processing matrix image rotation Engineering, Comp Sci, & Technology Homework 1
