Working through spivak's calculus
  • Thread starter Thread starter Shylock
    Calculus
The discussion revolves around solving problems from Spivak's calculus text, specifically focusing on the concepts of maximum and minimum values of numbers. Participants express challenges in understanding the proofs and reasoning behind the formulas presented in the exercises.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants share their experiences with specific problems, particularly problem 13, and discuss the difficulty of deriving formulas for max and min functions. Questions arise about the reasoning behind checking different cases and the validity of their approaches.
Some participants have offered guidance on how to approach the proofs by considering different cases. There is an ongoing exploration of the formal structure of proofs, with some expressing uncertainty about the rigor required in their explanations.
Participants note that Spivak's exercises can be quite challenging and that formal proofs may not be necessary for all problems in the book. There is mention of additional resources for learning about proofs, suggesting a mix of self-study and community support.
Shylock
i'm looking for some general advice on how to go about solving the problems in spivak's calculus text. I've just finished reading the first chapter, and while I've managed to solve some of the problems, i can't make sense out of most of them without referring to the solutions. how should i be going about this?
also, which of these problems do you think I should be able to do? I've taken calcI, intro to logic, symbolic logic, and intermediate logic I, with As in each.
Well, what question is troubling you? And what's the difficulty??
(I must add that Spivak's exercises can be quite difficult, so don't worry if you don't succeed at first)
i'm good till problem 13:
The maximum of two numbers x and y is denoted by max(x,y). Thus max(-1,3) = max(3,3) = 3 and max(-1,-4) = max(-4,-1) = -1. The minimum of x and y is denoted by min(x,y,). Prove that
max(x,y) = (x + y + ly - xl) / 2
min(x,y) = (x + y - ly - xl) / 2
Derive a formula for max(x,y,z) and min(x,y,z), using, for example,
max(x,y,z)=max(x,max(y,z)).
i'm pretty lost on where to start.
Well, let's prove that
[tex]\max(x,y)=\frac{x+y+|y-x|}{2}[/tex]
there are three possibilities: x=y, x<y and y<x. What is |x-y| in all these cases??
0, y-x, -x-y?
Shylock said:
0, y-x, -x-y?
Yes, and what do you get when you apply this in the formula
[tex]\frac{x+y+|y-x|}{2}[/tex]
(x+y)/2 , y , 0
how do you know to check for the three possibilities?
Shylock said:
0, y-x, -x-y?
Oh, sorry, the last one is not correct. That must be -x+y :smile:
So, plugging that in in our formula, we get
(x+y)/2, y, x
So, doesn't that prove our result?
Well, the absolute value is annoying, so we must eliminate it. The only way to do that is to do the prove in separate cases.
So, if we had somewhere [itex]|x^2+y+z^2|+z[/itex] for example, then we would have to split it up in the case that [itex]x^2+y+z^2[/itex] is < = or > than 0.
i still don't understand what we've just done
We have just calculated
depending on whether x<y, x=y or y<x...
i think i understand, but could you perhaps write the proof a bit more formally?
and does that that mean that the formula for max(x,y,z) =
x + (y+z + ly -zl)/2 ?
How did you find that??
proof by cases:
(i) if x=y then max(x,y) = (x+y)/2
(ii) if the x<y then max(x,y) = y
(iii) if x>y then max(x,y) = x
thus, for any numbers x,y max(x,y) = (x+y+ly-xl)/2
by substitution
although now that it think about it, that doesn't seem right
Shylock said:
proof by cases:
That seems ok. (also note that if x=y, then (x+y)/2=x)
Shylock said:
by substitution
Yes, substitution is the way to solve this. But I can totally not understand, how you arrived at that formula by substitution.
You know that
[tex]max{x,u}=\frac{x+u+|x-u|}{2}[/tex]
So, what if I substitute u=max(x,y)?
i think i tried to do it in my head and i got lucky, haha
but now you've lost me
well, not lucky
do you mean u = max(y,z)?
so hopefully i did this right
{[x+(y+z+ly-zl)/2]+[l(y+z+ly-zl)/2 - x]l}/2 ?
would this solution be acceptable or would i have to simplify it?
Yes, that's good! I don't think simplifying will give you much more nicer results, so I guess that this is acceptable :smile:
Could you show me what the formal proof would look like? It seems that the proofs I was taught to do in logic were more rigorous with the language and explanation. For example, do I need to cite the rules?
Does Spivak go into more detail about doing this, or is this something I need to work with on my own?
Formal proofs, like the ones you did in logic, are not being done here. It can be done, but it would be far too tedious. There are simply too many rules here.
A proof for this would look like this:
There are two possibilities: [itex]x\leq y[/itex] and [itex]y\leq x[/itex].
If [itex]x\leq y[/itex], then max(x,y)=y. Also, we have
[tex]\frac{x+y+|y-x|}{2}=\frac{x+y+y-x}{2}=y[/tex]
If [itex]y\leq x[/itex], then max(x,y)=x. Also, we have that
[tex]\frac{x+y+|y-x|}{2}=\frac{x+y-y+x}{2}=x[/tex]
So in both cases, we have
[tex]\frac{x+y+|y-x|}{2}=max(x,y)[/tex]
this proves the result.
I think that's as formal as you want it. If you want it more formal, you can, but it would be tougher to read.
No, he doesn't. You may want to pick up a proof book (like Velleman's) or "Understanding analysis" by Abbott to see how to do proofs.
so then i shouldn't be worried about having to write formal proofs for the problems in the book?
No, not at all. Formal proofs are not being done here :smile:
cool, thanks for the help
  • · Replies 17 ·
13K
12K
