Finding an orthonormal basis for a reproducing kernel Hilbert space.
This discussion focuses on characterizing a centered Gaussian random process ξ(x) on a manifold M using a known covariance function C(x,x'). The author, Aimless, seeks to find an orthonormal basis for the reproducing kernel Hilbert space (RKHS) H generated by C(x,x'). The key conclusion is that the RKHS consists of functions defined by a series expansion involving Gaussian random variables and that an orthonormal basis can be derived from a dense subset of M using the Gram-Schmidt process, provided C^{-1}(x,x') exists. The author also notes that while the RKHS is composed of continuous functions, its norm is not necessarily L^2.
  • Understanding of Gaussian random processes and their covariance functions.
  • Familiarity with reproducing kernel Hilbert spaces (RKHS) and their properties.
  • Knowledge of the Gram-Schmidt process for orthonormalization.
  • Basic concepts of functional analysis, particularly in relation to L^2 spaces.
  • Research the properties of reproducing kernel Hilbert spaces (RKHS) in detail.
  • Learn about the Gram-Schmidt process and its applications in functional spaces.
  • Explore the implications of covariance functions in Gaussian processes.
  • Investigate the behavior of RKHS in various metric spaces beyond Euclidean space.
Mathematicians, statisticians, and researchers working with Gaussian processes, as well as those involved in functional analysis and machine learning applications that utilize RKHS.
Aimless
Hello all,
I'm currently working on a problem in which I'm attempting to characterize a centered Gaussian random process \xi(x) on a manifold M given a known covariance function C(x,x') for that process. My current approach is to find a series expansion $\xi(x) = \sum_{n=1}^{\infty} X_n \phi_n(x)$ where the X_n's are Gaussian random variables with the standard distribution and the \phi_n(x)'s are the orthonormal basis functions of the reproducing kernel Hilbert space H generated by C(x,x'). I'm fairly certain that this procedure works so long as C^{-1}(x,x') exists, since that allows me to define the inner product for the RKHS.
However, I'm not sure how to proceed regarding finding an orthonormal basis for the RKHS. My RKHS should be some subset of L^2(M), so I assume that if I have an orthonormal basis on L^2(M) I should be able to find one for H. Is there a general procedure for this?
Thanks,
Aimless
Upon further consideration, I realized that I said something incorrect in the above post, but I think I might have also solved my problem. Comments and criticisms appreciated.
First, the mistake. While the RKHS will be composed of some subset of continuous functions on M, the norm will not in general be L^2.
To give a full definition of the RKHS, I start from the family of functions
[itex]S=\{u : M \to \mathbb{R} : u(\cdot) = \sum_{i=1}^n a_{i} C(\cdot,x_i)\}[/itex]
and define an inner product
[itex]\langle u(x),v(y) \rangle = \int_M \, dx \, dy \sum_{i=1}^n \sum_{j=1}^m a_i b_j C(x,x_i) C^{-1}(x,y) C(y,y_j) = \sum_{i=1}^n \sum_{j=1}^m a_i b_j C(x_i,y_j).[/itex]
The Hilbert space H is thus composed of all elements of S such that [itex]\langle u, u \rangle = \sum_{i=1}^n a_{i}^2 C(x_i,x_i) < \infty .[/itex]
So, as a possible answer to my original question, let the points [itex]\{ z_i \}[/itex] be a countable dense subset of M, and I should have a (non-orthonormal) basis for H in the form of the family of functions [itex]\{ C(x,z_i) \}[/itex]. From there, if I apply the Gram-Schmidt process, that should give me orthonormality, correct?
From there, for the purposes of numerically analyzing the Gaussian process [itex]\xi(x)[/itex], it should just be a matter of calculating the [itex]\{ C(x,z_i) \}[/itex] functions on a lattice of points to obtain an approximate solution.
I know that the above will work if M is simply Euclidean space so long as [itex]C^{-1}[/itex] exists. What about metric spaces?
  • · Replies 0 ·
