Absolute Maximum and Minimum Values over a given interval
by redbird555
Tags: absolute, interval, maximum, minimum, values
redbird555
redbird555 is offline
#1
Jul17-11, 02:26 PM
P: 12
Find the absolute maximum and absolute minimum values of the function
(x^3)+(12x^2)-27x+9
on each of the following interval
[-10,0]
3. The attempt at a solution
I got this and its saying its wrong.
y'= (3x^2)+(24x)-27
factor: 3(x^2+8x-9) so x=-9 and x=-1
y''=6x+24
I plug in -9 into there and come up with -30 as the minimum which is not correct?
Anyone have some input?
Thanks! Dan
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
1MileCrash
1MileCrash is online now
#2
Jul17-11, 02:48 PM
1MileCrash's Avatar
P: 1,227
You need to plug those numbers into the original equation. -9 is actually going to be a max value over your interval, not minimum. What do you get when you solve [itex]y = x^3 + 12x^2 - 27x + 9[/itex] for when x = -9?
Also, -1 is not a solution. Check your factoring again:
[itex]0 = x^2 + 8x - 9[/itex]
[itex]0 = ( x - 1 )( x + 9 )[/itex]
redbird555
#3
Jul17-11, 04:26 PM
P: 12
Thanks! I knew I had to plug it back in but for some reason I was getting the wrong answer when I plugged it in the equation the first time hahah. I managed to get all the other questions done except for this, I know I need to do the quotient rule but the equation I get for y' doesnt make any sense.
Find y' and the critical numbers for
(4x+1)/(x^2+x+1) I end up getting (4x^2+12x+2)/(x^2+x+1)^2 which I can factor the top and get (2(2x^2+12x+2))/(x^2+x+1)^2.
To me this is y' but I dont quite see how to get the critical numbers?
1MileCrash
#4
Jul17-11, 04:47 PM
1MileCrash's Avatar
P: 1,227
Critical numbers come from multiple places. A critical number is a location where min/max is possible. Ergo, max/min is always a critical number. By finding all critical x points, you can find the max/mins of the function by finding each corresponding y value. Above, our critical numbers were -9, 1, -10, and 0.
-A critical number is at the start and end of your interval, but you didn't list an interval. If they didn't give you one, then ignore that.
-A critical number is also any point where y' = 0, which we found above.
You can find the critical numbers by finding y' and setting y' = 0. However, your derivative is incorrect. Make sure you are applying the quotient rule correctly, or you can show your work if you want and I'll see if I can find the error.
So, just try again at finding the derivative of y = (4x+1)/(x^2+x+1), then find the x values where y' = 0. You'll need to use the quadratic formula for this one.
redbird555
#5
Jul17-11, 06:41 PM
P: 12
for the derivative per the quotient rule I got [(4x+6)(2x+1)-(4)(x^2+x+1)]/(x^2+x+1)^2 from there I multiplied out the top and got (4x^2+12x+2)/(x^2+x+1)^2 then I factored out a 2 from the top to give the equation i gave in my last post. I'm a little weary about factoring out that 2 though as in is it correct? Or should I just use the quadratic formula on (4x^2+12x+2)/(x^2+x+1)^2? If so wouldnt I use the quadratic on top, get the possible values of x then set the bottom equal to 0 and solve for the bottom? Uggh this problem is driving me nuts lol
redbird555
#6
Jul17-11, 06:49 PM
P: 12
never mind lol I got it I used the quaratic on the top part of (4x^2+12x+2) and got the values and those ended up being my critical numbers. One thing though how come I didnt need to factor and solve the bottom? I thought that when a derivative was in the form of a fraction the top and bottom had to be solved for to get all the critical zeros?
1MileCrash
#7
Jul17-11, 06:51 PM
1MileCrash's Avatar
P: 1,227
Your mistake on the quotient rule is only that you must put the nonderived denomenator times the derived numerator first, the order matters since you're subtracting.
You have:
Try instead:
[(4)(x^2+x+1) - (4x+6)(2x+1)]/(x^2+x+1)^2
You don't need to factor and solve the bottom because you're setting everything equal to 0. In order for a ratio to be equal to zero, the numerator must be equal to zero, so we just set the numerator to be zero and discard the bottom (alternatively, we can multiply both sides by the denominator, which is the same thing.)
[itex]y = \frac{4x+1}{x^2+x+1}[/itex]
[itex]y' = \frac{(4)(x^2+x+1) - (4x+1)(2x+1)}{(x^2+x+1)^2}[/itex]
[itex]y' = \frac{4x^2+4x+4-8x^2-4x-2x-1}{(x^2+x+1)^2}[/itex]
[itex]y' = \frac{-4x^2-2x+3}{(x^2+x+1)^2}[/itex]
Always remember that! For the quotient rule, the denominator times the derivative of the numerator comes first, always! It's a very common error.
Now,
[itex]\frac{-4x^2-2x+3}{(x^2+x+1)^2} = 0[/itex]
[itex]-4x^2-2x+3 = 0[/itex]
Ray Vickson
Ray Vickson is offline
#8
Jul17-11, 07:50 PM
HW Helper
Thanks
P: 4,670
Quote Quote by redbird555 View Post
(x^3)+(12x^2)-27x+9
[-10,0]
y'= (3x^2)+(24x)-27
y''=6x+24
Thanks! Dan
The critical values of y' are at x = -9 and x = 1. However, x = 1 is outside your stated interval [-10,0]. To find max/min in a case like this (i.e., with *bound* constraints on x) you need to examine both interior stationary points, and the end points as well. Here, there are two local minima (at x = -10 and at x = 0) and one local maximum (at x = -9). The left-hand end-point x = -10 is a local mininum because y' > 0 there; the right-hand end-point x = 0 is a local minimum because y' < 0 there. Point x = 0 is the absolute minimum on the interval [-10,0] because y(0) < y(-10); that is, y(0) is smaller than any other value y(x) in the interval. The point x = -9 is the absolute maximum on the interval.
The moral of the story is: in a *constrained* problem, the derivative does not need to vanish at a max or min that lies on the boundary of the constraint region. (For higher dimensions, we get involved with the so-called Karush-Kuhn-Tucker conditions, which are basically multivariate versions of the type of end-point conditions above.)
RGV
Register to reply
Related Discussions
Maximum/Minimum values of a graph on a restricted interval Calculus & Beyond Homework 2
Absolute Maximum/Minimum Help Calculus & Beyond Homework 2
Finding the absolute maximum and absolute minimum Calculus & Beyond Homework 5
Absolute minimum and maximum Calculus & Beyond Homework 11
Finding absolute minimum and maximum values Calculus & Beyond Homework 5
