Question about earth being much more radioactive in the past?
  • Thread starter Thread starter udtsith
    Earth Radioactive
The discussion revolves around the historical levels of radioactive decay on Earth and its implications for geological activity and life. Participants explore the heat generated from radioactive decay at different points in Earth's history, particularly 2 billion and 4 billion years ago, and consider the effects on plate tectonics and volcanic activity.
  • One participant notes that current estimates suggest Earth generates 44 terawatts of heat, with 23 terawatts from radioactive decay, prompting questions about past decay rates and their effects on geological processes.
  • Another participant suggests that increased heat from radioactive decay in the past may have influenced primordial plate tectonics and volcanic activity, potentially leading to the formation of 'diamond pipes'.
  • A participant presents a mathematical model to estimate past heat production from radioactive decay, concluding that while past heat levels may have been higher, the qualitative differences in geological activity might not have been substantial.
  • There is a query about whether the Moon would generate a similar amount of heat from radioactive decay if it originated from a large impact, considering the Earth's non-homogeneous nature.
  • Concerns are raised about the uniqueness of ancient volcanic materials and their relation to higher temperatures in the past, with references to specific types of lava that are no longer produced today.
Participants express various hypotheses regarding the implications of historical radioactive decay levels, but there is no consensus on the extent of its impact on life or geological processes. Multiple competing views remain on the significance of these factors.
Participants acknowledge the limitations of their models, including assumptions about the decay constants and the potential influence of other sources of radioactivity. The discussion also highlights the complexity of geological processes and the non-homogeneous nature of the Earth and Moon.
udtsith
I read a recent article (pc magazine) that said the Earth is currently generating 44 terawatts of heat with 23 terawatts comign from radioactive decay (8 from uranium, 8 from thorium, and 4 from potassium). Given this, and that the Earth is 4.5 billion years old...how many more terawatts were coming from radioactive decay at 2 billion and 4 billion years ago?
What sort of affect would this have had on life and the continents moving?
Assuming the longest-lived (radioactive) isotopes of those elements are producing the heat, the decay constants are: K40-1.248E9 yrs., U238-4.537E9 yrs., Th232-1.40E10 (ref. http://www.nndc.bnl.gov/chart/" ). Given the amount of a radioactive element present now,N0, the amount a given time, t, ago would be N(t)=N0et*ln(2)/D, where D is one of the half-life values given above. Assuming the amount of heat produced is proportional to the rate of decay, H(t)=H0et*ln(2)/D, where H0 is the amount of heat being produced by the element today. Adding up the values for each of the elements I get: Hnow= 20 TW H2 Gya≈ 32 TW H4 Gya≈ 61 TW. I cannot speak definitively on your last question, but since the largest value is only about 3 times larger than the current one I doubt there would be a large qualitative difference (maybe volcanos would have been somewhat more common and plate tectonics somewhat faster). Life is not likely to have been greatly influenced by this extra heat (at least not directly, though the geological effects might have had some influence) since the Sun usually provides much more heat. Of course it is possible that other sources of radioactivity were also significant long enough ago (so my estimate above is more of a lower bound on the amount of heat due to radioactivity at those points in the past).
So if 23 TeraWatts is coming from radioactive decay. Then should that mean that in relative proportion to the size of the Earth, the Moon will be generating the same if the theory of a large early impact is its origin?
I am not a geologist or a volcanist, so I could have this wrong, but there are some ancient volcanoes, which are said to have erupted somewhat unique material, probably due to the high temperatures, not entirely sure...
"No modern komatiite lavas are known, as the Earth's mantle has cooled too much to produce highly magnesian magmas."
Ultra Mafic - http://en.wikipedia.org/wiki/Lava#Ultramafic_lava
The Earth is not homogeneous. Therefore, if the Moon is a chip off the old block, who's to say it's a homogeneous chip? More than likely it took a large chunk of mantle.
  • · Replies 25 ·
15K
  • · Replies 67 ·
9K
