How do I interpret the units of my discrete convolution results?
  • Context: Undergrad
  • Thread starter Thread starter csand
    Discrete
This discussion focuses on interpreting the results of discrete convolution involving high-resolution spectra and a Gaussian curve. The convolution operation produces a new function whose length is calculated as len(1) + len(2) - 1, where len(1) is the length of the high-resolution spectrum and len(2) is the length of the Gaussian kernel. To accurately map the convoluted values to the original wavelength units, the convolution result should be centered around the original data, with the outer values trimmed to avoid contamination from padding. The central values of the convolved data, specifically l1 - l2 + 1, are deemed reliable.
  • Understanding of discrete convolution operations
  • Familiarity with high-resolution spectral data
  • Knowledge of Gaussian functions and their properties
  • Basic concepts of data padding in signal processing
  • Research the mathematical principles of discrete convolution
  • Learn about Gaussian filtering techniques and their applications
  • Explore methods for interpreting and visualizing convolution results
  • Study the effects of data padding on convolution outcomes
Researchers, data analysts, and scientists working with spectral data and convolution techniques, particularly those seeking to understand the implications of convolution on data interpretation.
csand
I'm having trouble understanding the results of a discrete convolution. I have two functions:
1) High resolution spectra
2) Gaussian curve
The point of this operation for me is put the high resolution data in terms of the lower resolution represented by the guassian curve (filter)
I convolve one with the other, and the results seem reasonable. However I do not understand how to interpret my units.
It is my understanding that the final "length" or domain of my convoluted function will be:
len(1) + len(2) - 1.
So if I'm dealing in wavelengths or such units for my original function (1), how do I now map my new convoluted values to wavelengths? The domain of my convoluted function is bigger than either domain other the two original functions.
Do I "center" my convoluted data around the original data (1) and trim the values on the outside?
My understanding of this is limited so I hope the context to the question I've asked is understandable. I can try to elaborate if more information is required.
Thanks in advance,
Chris
Mathematics news on Phys.org
I'm going to assume that l1 is the length of your spectrum, l2 the length of your Gaussian kernel, and that l2 is odd. In that case, point i in your original spectrum corresponds to point i + (l2-1)/2 in the convolved spectrum. (So, yes, if you center the old on the new, you'll have the right correspondence.) Also, the length you give, l = l1 + l2 - 1, indicates that the real data are being padded at the ends when you do your convolution. You should not trust the end of the convolved spectrum. Only the central l1 - l2 + 1 values of the convolved data are free from contamination by the padding.
Thanks for the reply,
-C
  • · Replies 17 ·
