| New Reply |
What is the best Unix like OS for mathematical computation? |
Share Thread | Thread Tools |
| Jul19-11, 06:04 PM | #1 |
I want to basically have a dedicated machine for running scientific computation programs and be able to access it remotely anywhere using a laptop/netbook. That means I don’t care much about GUIs. I’m used to using Unix and am perfectly fine with doing everything through a command window. At the same time however, I’m not a skilled programmer and want whichever is easiest to set-up and run things on. I also, need the OS to be able to run MATLAB.
So basically I want to find out which is the best OS for creating numerical analysis programs in C/C++/Fortran/MATLAB which leads me to these questions:
Also on a slightly related topic, can I just build my own home server for cheap? By cheap I mean a budget under $2,500 |
| Jul24-11, 10:13 AM | #2 |
I think the better unix OS is debian, but it's something complicated for using because need knowledge of shell script , so I recommend you to use Ubuntu.
And the server... you can turn your computer in server, there is a lot of software to can do this. |
| Jul24-11, 12:59 PM | #3 |
I haven't used it myself, but Scientific Linux, which is a joint project of FermiLab and CERN, might fit your needs. It's based on RHEL.
http://www.scientificlinux.org/ Any of the Linuxes should work, though. Not sure about BSDs, with ports it might work. |
| New Reply |
| Thread Tools | |
Similar Threads for: What is the best Unix like OS for mathematical computation?
| Unix / scripting help | Programming & Comp Sci | 3 | ||
| UNIX scp script | Programming & Comp Sci | 3 | ||
| Use of LINUX inter-process communication (IPC) to implement a game | Engineering, Comp Sci, & Technology Homework | 0 | ||
| looking for Info regarding Unix | Computing & Technology | 1 | ||
