How high above the the earth's surface is the meteor?
  • Thread starter Thread starter fa08ti
    Meteor Surface
The discussion revolves around a problem involving the gravitational acceleration of a meteor falling towards Earth and the calculation of its height above the Earth's surface. The subject area includes concepts from gravitational physics and kinematics.
  • Participants discuss the appropriate formulas to relate gravitational acceleration to distance from the Earth's center. There is uncertainty about which variables to use and how to apply the formulas correctly.
Participants are actively engaging with the problem, questioning the use of mass in calculations and clarifying the role of gravitational acceleration. Some have provided guidance on the correct formulas, while others are exploring the implications of their calculations.
There is a noted confusion regarding the use of the meteor's mass versus the Earth's mass in the calculations. Participants are also addressing the implications of obtaining negative values in their results, indicating a need for further clarification on the assumptions made in the problem.
fa08ti
a 12 kg meteor experiences an acceleration if 7.2 m/s^2. when falling towards the earth
a: how high above the the Earth's surface is the meteor?
b: what force will a 30 kg meteor experience at the same altitude?
attempt:
i'm, not sure which equation to use..would it be
v= sqrt(Gm/r)?
You need a formula which relates acceleration due to the Earth's gravity and the distance from it's center. Do you know such a formula?
would this be correct?
gh = GM / (R + h )2
If R is the radius of the earth, and h above the surface of the earth, yes.
[itex]g=\frac{GM}{(R+h)^{2}}[/itex]
i used the formula and got a negative value?
How did you get a negative value? g should come out to 9.8m/s^2 if h=0. Do you know why? To get 7.2m/s^2, h should certainly be positive.
i used the mass of the meteor and i think i should have used the mass of earth?
Very correct.
thanks..i just want someone to clarify something..does the mass of the object not matter? if so, why not?
The mass of the object does not matter. Every mass falls with the same acceleration (in a given gravitational field).
[tex]F = G\frac{M m}{r^2}[/tex]
but [itex]F = m a[/itex] so that [itex]a = F/m[/itex] Thus
[tex]a = \frac{F}{m} = G\frac{M}{r^2}[/tex]
Only the mass of the Earth, M, matters for the acceleration of mass m in its field (that's the acceleration with respect to the Earth, of course).
So, why should this be so? It is so because inertial mass happens to be equal to gravitational mass for any object with mass (Look up "equivalence principle").
thanks everyone sooo much
