Gauss's Law with non-uniform E-field
The problem involves a long insulating cylinder with a non-uniform charge density given by \(\rho = e^{ar}\), where \(r\) is the distance from the axis of the cylinder. Participants are tasked with finding the electric field both inside and outside the cylinder.
  • Mixed
  • Participants discuss the application of Gauss's Law and the need to integrate to find the total charge within a Gaussian surface. There are attempts to clarify the volume elements and the integration limits. Questions arise about the implications of non-uniform charge density and how it affects calculations.
The discussion is active, with participants exploring different aspects of the problem, including the integration process and the implications of charge density variations. Some guidance has been offered regarding the assumptions made in calculating the electric field, particularly in relation to symmetry and the components of the electric field.
Participants are navigating the complexities introduced by the non-uniform charge density and questioning the relevance of volume ratios in this context. There is an ongoing exploration of the physical implications of certain charge distributions, such as those leading to infinite charge at the axis of the cylinder.
flyingpig
A long insulating cylinder has radius R, length l, and a non-uniform charge density per volume [tex]\rho = e^{ar}[/tex] where r is the distance from the axis of the cylinder. Find the electric field from the center of the axis for
i) r < R
ii) r > R
i)
[tex]\oint \vec{E} \cdot d\vec{A} = \frac{\sum Q_{en}}{\epsilon_0}[/tex]
[tex]\vec{E} 2\pi rl = \frac{\sum Q_{en}}{\epsilon_0}[/tex]
So now here is the problem, if it is inside the cylinder I get something like
(1) [tex]\rho V = Q[/tex]
(2) [tex]\rho V' = Q_{en}[/tex]
Divide them out and some algebra and I get
[tex]Q\frac{V'}{V} = Q_{en}[/tex]
Should I keep this? Does it even matter if it was a non-uniform density?
I will stop here before I do ii...
You must integrate to find the total charge within your Gaussian surface.
[tex]V = \frac{4 \pi r^3}{3}[/tex]
[tex]dV = 4\pi r^2 dr[/tex]
[tex]\rho dV = e^{ar} 4\pi r^2 dr[/tex]
Integrate that? This is just an indefinite integral right?
Almost. It's a cylinder, not a sphere.
Oh wait, what am i doing lol
[tex]V = \pi r^2 l[/tex]
[tex]dV = 2\pi rl dr[/tex]
[tex]\rho dV = e^{ar} 2\pi rl dr[/tex]
Good.
Definite or indefinite integral? What are my limits?
You want the total charge from 0 to r.
I had a feeling it was going to be a "0" to something
What happens if [tex]\rho = \frac{1}{r}[/tex]
What would the discontinuity mean? Would it mean that there is no Electric field in the line of its axis?
So anyways...
[tex]2\pi l\int_{0}^{r} re^{ar} dr = 2\pi l \frac{e^{ar} (ar - 1) + 1}{a^2}[/tex]
[tex]\vec{E} = \frac{1}{\epsilon_0 r}\frac{e^{ar} (ar - 1) + 1}{a^2}[/tex]
So how do I tell the direction...? It looks all positive, it radiates outward?
So do I still need to take the ratios between the volumes?
Hi flyingpig! :smile:
Such a distribution would mean you have infinite charge at the axis of the cylinder.
That's not physically possible.
flyingpig said:
So anyways...
You did not calculate the vector E, so you shouldn't write it down that way.
You only calculated the component of E that is perpendicular to the surface that you integrated, which is the radial component.
Furthermore you have assumed that it is the same everywhere on the surface of the cylinder.
This is a reasonable assumption for a long cylinder with a symmetric distribution of charge.
There are 2 more components to the E field at any point.
Typically you would express them in cylindrical coordinates, meaning you have a component along the length of the cylinder, and a tangential component in the direction of the angle.
Can you deduce what these components are?
Which ratio? :confused:
flyingpig said:
So anyways...
Looks good. That's the charge.
Good. (If you want to express it as a vector, include a unit vector to show the direction.)
Yes. Assuming the charge is positive, the field points outward.
What happens if I say [tex]\rho(0) = c[/tex] and treat it as a piecewise function?
[tex]\frac{Q_{en}}{Q_{charge\;of\;cylinder}}[/tex]
[tex]\frac{\int \rho dV}{\rho V} = \frac{Q_{en}}{Q_{charge of cylinder}}[/tex]
[tex]\frac{Q_{charge\;of\;cylinder}\int \rho dV}{\rho V} = Q_{en}[/tex]
For [tex]\rhoV = e^{ar} 2\pi Rl[/tex]
Where R is the radius of the cylinder
dV is proportional to r, so the effect of 1/r would be canceled out when you integrate to find the charge..
Symmetry shows that there E=0 along the axis.
Well, with a function like 1/r the charge will still be near infinity if you get close enough to zero.
Still physically impossible.
Sorry.
Errr... no, Gauss's formula for electric field and enclosed charge does not involve such a ratio.
Yeah it does, for an insulating surface with uniform density.
I was thinking of
[tex]\frac{Q_{charge\;of\;cylinder}\int \rho dV}{\rho V} = \frac{Q_{charge\;of\;cylinder}2\pi l \frac{e^{ar} (ar - 1) + 1}{a^2}}{e^{ar} \pi R^2 l}= Q_{en}[/tex]
I was thinking of
:confused:
[tex]Q_{en} = \int \rho dV[/tex]
No ratios.
Say the density was uniform, then we need ratios. So why don't we have ratios here??
If you know the density, why do you need a ratio?
Because the charge enclosed inside the cylinder has a smaller Gaussan volume
So?...
What you're probably thinking is that if you know the total charge per length of the cylinder, then you can use a ratio of volumes to find the charge enclosed in a Gaussian surface within the cylinder.
Qenclosed = Qtotal (Volume enclosed/Volume total)
But not necessary if you know the density.
OKay i'll just pull an example from where I got this idea of volume ratios
[PLAIN]http://img585.imageshack.us/img585/1779/unled2jp.jpg
The volume ratio works for this example because the charge density is uniform throughout the sphere.
Why does being non-uniform make it any different?
Is there no meaning in this?
As I said earlier, the charge is always:
When the charge density is constant you can pull it out of the integral and then use the ratio of volumes and the total charge, if you like. (But why?)
When the charge density is not constant, you cannot do that.
It seems quite convoluted. (Note that, since the charge density is not constant, [itex]\rho V[/itex] doesn't mean what I assume you think it means.)
Sorry at the end i meant
[tex]\frac{Q_{charge\;of\;cylinder}2\pi l \frac{e^{ar} (ar - 1) + 1}{a^2}}{e^{aR} \pi R^2}[/tex]
Like I evalutated the non-uniform density at R for e^ar
(Check your use of braces in your latex expression)
Okay fixed! thanks
  • · Replies 26 ·
  • · Replies 30 ·
