Designing a Voltage Subtractor Circuit Without an Op-Amp
  • Context: Undergrad
  • Thread starter Thread starter chroot
    Subtracting
The discussion centers on the design of a voltage subtractor circuit that can produce an output voltage equal to the difference between two input voltages, specifically without the use of operational amplifiers (op-amps) and while functioning with only one positive supply. Participants explore various methods and historical approaches to achieve this goal.
  • Warren initiates the discussion by asking for a circuit design that can subtract two voltages without using op-amps and questions historical methods used before op-amps were common.
  • One participant suggests that reversing battery connections could illustrate voltage differences, but Warren clarifies that this analogy does not apply to his scenario with temperature sensors.
  • Another participant proposes isolating one temperature sensor from ground to change connections, while Warren explains he can use separate ground voltages for the sensors.
  • Warren describes a scenario where two sensors produce different voltages above their respective grounds and seeks a method to subtract these voltages to achieve a specific output.
  • A participant raises questions about the intended precision, frequency range, and other specifications, suggesting a capacitor-based solution with FETs, but notes that it would be a discrete sampler with limitations.
  • Some participants express skepticism about achieving the goal without op-amps, with one stating that passive components alone may not suffice.
  • Another participant suggests that if the sensors could have floating grounds, a simple connection could allow for free subtraction, but acknowledges the need for a common ground.
  • A participant introduces the idea of using a Wheatstone bridge to achieve the desired voltage difference, suggesting that it could be a viable solution.
Participants generally disagree on the feasibility of designing a voltage subtractor circuit without op-amps. While some propose alternative methods, there is no consensus on a definitive solution, and several participants express doubts about the practicality of achieving the goal with only passive components.
Participants mention various assumptions regarding the use of separate ground voltages and the limitations of different circuit designs. The discussion includes unresolved questions about the precision and specifications of the proposed solutions.
chroot
Staff Emeritus
Can anyone think of a circuit that takes two input voltages and produce an output voltage equal to the difference in input voltages? In other words, a "voltage subtractor?"
And don't answer "op-amp!" I don't want to use an op-amp. The circuit also must function with only one positive supply.
Any ideas? Can it be done? What did people do in the pre op-amp days?
- Warren
Unless I'm reading the question wrong, this is precisely what happens when you put a battery into a device backwards. If you go -+,-+ with AA batteries, you get 3V. -+,+- gives you 0V.
russ,
I'm not dealing with batteries (which are chemical devices actively capable of maintaining a potential difference across their terminals). You can flip batteries upside down and they don't care, and continue maintaining 1.5V across their terminals from - to +.
I'm dealing with two aribtrary voltages, from two temperature sensors, referred to the same ground. I want to get the difference of the two, without having to use an op-amp. And no, you cannot "flip one upside down," since they are referred to the same ground.
- Warren
Are these thermistors?
You may just have to isolate one from the ground and change the connections.
Tyger,
I *can* use separate ground voltages for both temp sensors. One could be grounded at 0V, the other at, say 3V.
If one sensor is at 30 degrees C, it will produce 0.3V above its ground.
If the other is 50 degrees C, it will produce 0.5V above its ground.
If I used 0V and 3V as grounds, the sensor voltages would thus be appproximately, say, 0.3V and 3.5V. How could I then subtract them and get 0.2V?
- Warren
What is intended precision, frequency range (or latency), voltage range, linearity? What are impedances?
Charging capacitor between inputs and then switching (with FETs) it over to output with one leg grounded would do it. But it'd be discrete sampler, and cap discharges with time. so depends on application.
Substraction can lead to negative voltages. What do you mean by only working with positive volts?
Some sort of differential amplifier. But I'd think you'd find suitable opamp faster and cheaper than trying to reinvent it.
Yup... op-amps are really the only way to go. The switch-mode cap circuit would be a huge pain in the ass.
I was just hoping there was some tricky way, using only passive components, to subtract two voltages. This is obviously not true! Oh well.
- Warren
If these were simply 2 thermocouples you could connect them in series with positive ends (or negative) connected. This should do exactly what you want. (Thermocouples act just like batteries, with a varible voltage which depends on the temperature of the junction.)
Well, I can only say that scrapping switch-mode cap you deny yourself a lot of fun.
On other note, if your subtractor circuit can have floating ground relative to your sensors, then simplest way to have difference is to connect subtractor ground to one of sensors and use other sensor as input voltage. You have free subtraction. But I suppose you need common ground, or you wouldn't be asking..
If you can feed one sensor with negative voltage (common ground) and thus extract signal as negative voltage, then simple average sum of the two will always be 1/2 of their difference. job for simplest resistor network.
Chroot...why did you not want to use op-amps when they are the most obvious (and therefore easiest) way to go?
wait a min here...
what about using a wheatstone bridge?
http://www.electronics2000.com/basics/wheat01.jpg
Rs is originally set to be equal to Rx, and the sum of these two should be equal to R1+R2. when this is tipped one way by the sensor arm resistance changing (Rs), then the difference in voltage is expessed in the G (galvanometer) arm.
just a thought...
Try a wheatstone bridge circuit.
Richard
  • · Replies 16 ·
