Register to reply
What happens when you pluck a guitar string?
by physickkksss
Tags: guitar, pluck, string
Share this thread:
physickkksss
#1
Jul23-11, 09:21 PM
P: 28
Hi guys, I know the basics of waves and standing waves, but I am trying to understand what exactly happens when you pluck a guitar string...
So, due to standing waves, a string that is clamped down on both ends needs to vibrate in one of its resonant frequencies:
f = (harmonic number)* v/2L
But I've read that when you pluck a guitar string, the sound produced is a combination of ALL of the fundamental frequencies.
That does not make sense to me. When you pluck ONE string, can't it only vibrate at ONE frequency, and thus produce a pitch of that frequency?
Phys.Org News Partner Physics news on Phys.org
Engineers develop new sensor to detect tiny individual nanoparticles
Tiny particles have big potential in debate over nuclear proliferation
Ray tracing and beyond
olivermsun
#2
Jul23-11, 09:40 PM
P: 788
Think this one may have been discussed in the past, but basically think of the disturbance you make when you pluck the string. Instead of a sinusoid, it's more of a kink, right? So, it contains lots of sinusoidal components; the ones which survive are the fundamental wavelength of the string and integer multiples which also "fit" on the string, thereby producing the harmonics.
physickkksss
#3
Jul23-11, 10:05 PM
P: 28
Thanks for the reply
Quote Quote by olivermsun View Post
Ok I understand this part...one actually imparts many different frequencies on the string, but it can only vibrate at its fundamental harmonic (or a multiple)
This is the part I dont get. Cant ONE string only vibrate at ONE frequency?
So shouldn't the string settle at one of its harmonic frequencies and then produce a pitch at that frequency? How can it produce all of them at once?
bp_psy
#4
Jul23-11, 11:24 PM
P: 452
Quote Quote by physickkksss View Post
A string on a guitar can be considered as a series of damped oscillators. Each of these oscillators has a natural frequency. If you want to make a oscillator vibrate continuously at a frequency other than its natural frequency you must supply it with with energy ,this is called driven oscillator.If you stop the driving force the oscillator it will eventually damp the driving frequency and vibrate at its natural frequency and its harmonics until it completely stops .For an oscillator the natural frequency is given by its constant physical properties like spring constant and mass, inductance and capacitance.When you pluck a string you make all parts of the guitar vibrate at multiple frequencies but since the pluck originates from a string that is composed from a series of oscillators that have the same natural frequency, most of the frequencies will be damped quickly.What will have the most energy when the vibration will final propagate trough the whole guitar is the note you plucked and its harmonics. This is pretty much what makes a musical instrument possible.
You could make a string vibrate at just some frequency but just by driving it with some single frequency driving force. With a pluck of a string this can't be achieved because what you do is make the string vibrate at multiple frequencies but it chooses at what frequencies to vibrate .
For the question "How can it produce all of them at once?" i recommend you play with this :
http://www.falstad.com/loadedstring/
I like Serena
#5
Jul23-11, 11:45 PM
HW Helper
I like Serena's Avatar
P: 6,188
I believe you can get a string to vibrate at (almost) exactly one frequency if you enforce it by for instance connecting the string to an electronic sinusoidal wave generator.
As for how multiple harmonics can be in a string at once, look for instance at this picture:
The various waves are superimposed on each other.
physickkksss
#6
Jul24-11, 09:53 AM
P: 28
cool, those replies helped a lot
rcgldr
#7
Jul24-11, 12:25 PM
HW Helper
P: 7,133
It might help to visualize a string with a combination of fundamental and double frequency. The double frequency on it's own would have a staionary node at the mid point of the string, but combined with the fundamental frequency, that node oscillates at the fundemental frequency. A guitar player can place his finger lightly on the mid point of the string to prevent node movement and pluck it at about 1/4 the way down the string to get a mostly double frequency sound.
Although the overall output of a guitar string is a composite waveform, the entire string movement does not follow that composite waveform. Instead the actual string movement at any point on the string is affected by the nearness of the nodes and peaks related to the frequencies produced by the string. From a 2d side view at any moment in time, you would see peaks and valleys along the length of the string due to the combined frequencies.
The soundboard of the guitar that actually produces the sound, also has pockets of peaks and valleys related to the frequency being produce.
Link to a video someone made of guitar string movement, the first one is affected by the rotating shutter, so the second one is a better example.
http://createdigitalmusic.com/2011/0...hone-shutters/
I like Serena
#8
Jul24-11, 01:05 PM
HW Helper
P: 6,188
Quote Quote by rcgldr View Post
Nice video!
It's one thing to more or less know how things work, but it's quite another to actually see it!
physickkksss
#9
Jul24-11, 04:27 PM
P: 28
Also I wanted to follow up about the soundbox...
I understand that the string itself does not move a lot of air, so you cannot hear it
It transfers its vibrations to the soundboard, which moves much more air
This leaves the sound hole, and we get an amplified sound
My question is that wouldn't the wood need to have the same harmonic frequencies as the string? (ie. a tuning fork can only transfer its sound by resonance to a tuning fork with the same natural frequency).
If the wood is indeed selected to have the same natural frequency of the string, then how does it resonate with all of the different strings on the guitar?
I like Serena
#10
Jul24-11, 04:37 PM
HW Helper
P: 6,188
A string is designed to have a specific resonance frequency determined by its length.
A soundboard is designed to not have a resonance frequency.
It will vibrate with any frequency.
Btw, the majority of the sound does not leave the soundboard by the sound hole.
olivermsun
#11
Jul24-11, 05:51 PM
P: 788
I don't know how a guitar works specifically, but I have seen analysis of the body of stringed instruments such as the violin, and actually there are many vibrating modes. Here the varying thicknesses of the wood, the shape of the body, and the cavity contained in the body, allow much more complicated resonances than the resonances in the string. So, I would guess that the guitar soundboard and body also have many distinct resonances rather than none.
physickkksss
#12
Jul24-11, 10:21 PM
P: 28
Quote Quote by I like Serena View Post
How does that fit with the statement:
all objects have a natural frequency or set of frequencies at which they vibrate when struck, plucked, strummed or somehow disturbed
Maybe its because normally objects quickly damp out frequencies other than its natural frequency, so the soundbox just does not damp out all those other frequencies too much?
I like Serena
#13
Jul25-11, 12:16 AM
HW Helper
P: 6,188
Yeah, well, if you knock on the soundboard it will indeed vibrate with a characteristic set of frequencies.
But it can also vibrate at other frequencies without really dampening out.
However, if you make a string vibrate with a frequency that does not match its length, it will dampen out immediately.
physickkksss
#14
Jul25-11, 02:20 AM
P: 28
Yeah so I guess that must be it....
The soundboard, like any other object, does have its own natural frequency that it is prone to vibrate at. However, it must have the quality of not quickly dampening out other frequences, as would most other objects. That would make it good at transferring the vibrational frequencies of all the guitar strings.
chingel
#15
Jul25-11, 03:37 AM
P: 261
I think the soundboard is just carrying the sound waves and vibrating along with it. Just like air can vibrate at all sorts of frequencies and carry all sorts of sound waves. The string is against the bridge, which is against the soundboard, the string gives it's vibrations to the soundboard, which carries them and vibrates along.
Why does a string dampen out immediately if I make it vibrate at a frequency that does not match it's length?
sophiecentaur
#16
Jul25-11, 04:00 AM
Sci Advisor
Thanks
PF Gold
sophiecentaur's Avatar
P: 12,186
Quote Quote by chingel View Post
Say you excite the string with a nearby loudspeaker. The energy from the loudspeaker, whatever frequency, will hit the string and make it vibrate and it will dissipate. However, if the frequency of sound from the LS happens to be at a suitable frequency, the vibrations, being in step, will add up (build up) and cause the string to vibrate with a high amplitude because some of the energy is being absorbed into the resonant system. Once enough energy has been absorbed onto the system, it will, as before, dissipate at the rate it is being supplied and the string will be vibrating at the maximum amplitude. The resonant system can only store energy at certain frequencies, which is why it only 'responds' to those frequencies. A string on a solid bodied guitar will have fewer losses than on an acoustic guitar so the resonance will be more 'frequency selective' and the note will sustain for longer when the excitation is removed and the energy gradually dissipates. (Hence the Brian May effect)
Pythagorean
#17
Jul25-11, 04:06 AM
PF Gold
Pythagorean's Avatar
P: 4,287
See "harmonic series (music)" as opposed to the mathematical concept.
sophiecentaur
#18
Jul25-11, 04:09 AM
Sci Advisor
Thanks
PF Gold
P: 12,186
Oh - you just opened another can of worms!!!
Yes; overtones from all musical instruments do not coincide exactly with harmonics of the fundamental. Nice to listen to but not nice to analyse.
Register to reply
Related Discussions
Guitar String and frequencies? Introductory Physics Homework 0
Wave on a guitar string Introductory Physics Homework 5
Emf max for a guitar string. Introductory Physics Homework 1
Guitar string..please help... Introductory Physics Homework 8
Polarization of a Guitar String General Physics 2
