Immediate source of the colored light produced by neon signs?
The immediate source of the colored light produced by neon signs is the excitation of gas particles within the tube when a stream of electrons passes through. This process involves electrons colliding with gas particles, which excites them to higher energy levels. As these electrons return to their original states, they emit light, with the color determined by the specific energy levels of the gas used and the voltage applied across the tube. Neon gas specifically contributes to the characteristic colors observed in neon signs.
  • Understanding of gas excitation and electron behavior
  • Familiarity with the principles of fluorescence
  • Knowledge of electrical voltage and its effects on gas
  • Basic concepts of light emission and photon energy
  • Research the properties of different gases used in neon signs
  • Learn about the physics of gas discharge lamps
  • Explore the impact of voltage on light color in gas tubes
  • Investigate the design and construction of neon sign circuits
This discussion is beneficial for electrical engineers, physicists, and anyone interested in the technology behind neon signage and gas discharge lighting systems.
dg_5021
immediate source of the colored light produced by "neon" signs?
What is the immediate source of the colored light produced by "neon" signs?
Chemistry news on Phys.org
What exactly do you mean by "immediate" source? Neon signs work by running a stream of electrons through a tube filled with a gas. The electrons in the gas particles are excited (bumped up to higher energy levels) by the electrons in the stream, and as they fall they emit the energy in the form of light. The colour depends on the frequency, which depend son the amount of energy possessed by each photon of light, all of which depends on the specific energy levels of the gas particles (so the type of gas) and the voltage across the tube.
I think fluorescence occurs in a vacuum tube with two electrodes in the presence of neon gas (this is a brief description of neon lamp). Sirus' explanations are sufficient in theory, if you don't look for more.
  • · Replies 20 ·
