Solving for two unknowns in a 2-D elastic collision. HELP
The discussion revolves around a 2-D elastic collision problem involving two pucks on an air-hockey table. The original poster describes the scenario with specific masses and initial velocities, noting the angles at which the pucks move apart after the collision. The challenge lies in determining the final speeds of both pucks, given that the problem results in two unknowns.
  • Participants discuss the application of conservation of momentum and kinetic energy to solve for the unknown final speeds. The original poster expresses frustration over ending up with two variables, despite attempts to set up equations based on these conservation laws.
There is ongoing exploration of the problem, with some participants suggesting the use of both conservation principles. However, the original poster remains uncertain about how to proceed due to the presence of two unknowns, and no consensus has been reached regarding a solution approach.
The original poster mentions a lack of specific final speed information, which complicates the problem-solving process. Additionally, there is an indication that the teaching assistant did not provide hints that could clarify the situation.
parthman5000
Hey everyone.
I am really stuck on a problem that seems simple but I just can't figure it out. The problem goes as follows.
There is a collision between two pucks on an air-hockey table. Puck A has a mass of 0.039 kg and is moving along the x-axis with a velocity of +5.5 m/s. It makes a collision with puck B, which has a mass of 0.064 kg and is initially at rest. After the collision, the two pucks fly apart with the angles of 65 deg for A and 37 deg for B.
I know this problem is really basic but i just can't figure it out unless I have one of the final speeds. Despite all of my work I will still end up with 2 variables. I have checked a bunch of examples but every single one them gives the final speed for one the pucks and the TA at my help session doesn't really give any hints as to how to solve this. Any help will be greatly appreciated.
Thank You
Did you apply energy conservation?
Yes I did let me show you my work:
X component:
(M1 x VAi) + (M2 x VBi) = (M1 x VAf cos theta) + (M1 x VBf cos theta)
Y component is the same except for cos is replaced by sin and negative VBf.
So I got this for X component:
(0.039 x 5.5) + (0.064 x 0) = (0.039 x VAf cos 65) + (0.064 x VBf cos 37)
and this for Y component:
(0.039 x 5.5) + (0.064 x 0) = (0.039 x VAf sin 65) + (0.064 x - VBf sin 37)
The intial side of the equation is easily solved but that leaves two unknowns on the final side causing my brain to hurt.
You used conservation of momentum, but not conservation of kinetic energy (In elastic collision kinetic energy is conserved).
I tried using the conservation of kinetic energy but it still leaves me with two unknowns on one side.
since Ki=Kf
Ki = (1/2 x M1 x VAi^2) + (1/2 x M1 x VBi^2) = (1/2 x M1 x VAf^2) + (1/2 x M1 x VBf^2) = Kf
So if I plug in my values it solves the initial side but not the final side because of the two unknown variables.
Anybody have an idea on how to solve this?
Hmm... I guess it can't be solved since there are two unknown variables unless I am forgetting something fairly obvious. (or maybe its too hard for all you physics masters :biggrin: )
Thanks anyway.
  • · Replies 16 ·
  • · Replies 35 ·
