Thread Closed
mass problem dealing with areas and lengths
Share Thread Thread Tools
Aug28-03, 05:55 PM   #1
Hello again,
The problem states that:
Gold has a mass of 19.32 g for each cubic centimeter of volume.
a) If 1.000 oz of gold, with a mass of 27.63 g, is pressed into a leaf of 1.000 micrometers thickness, what is the area of the leaf?
b) If the gold is drawn out into a cylindrical fiber of radius 2.500 micrometers, what is the length of the fiber?
Well,
From the first part of the problem I got this ratio:
1 cubic centimeter of gold : 19.32 g of gold
For part A:
I did a proportion:
1 cubic centimeter / 19.32 g = x / 27.63 g
x = 1.43 cubic centimeters = 1.43 x 10^-2 cubic meters
but that is where i got stuck. i think that the x that i found is the volume for the 1 oz of gold, but how do i get the length of the leaf so I can get the area? also, if the problem says that the leaf has a certain thickness, then is the area they are looking for a surface area?
For part B:
I first changed the 2.500 micrometers into meters and got: 2.500 x 10^-6 meters
the volume of a cylinder is: V = pi * r^2 * h
then from part A, V = 0.143 cubic meters
0.143 = pi * ( 2.500 x 10^6 )^2 * h
solving for h, i got: h = 7.283 x 10^8 meters
I think I can only get the right answer if I have the volume from part A correct, so I am unsure if my answer is correct.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Aug28-03, 06:12 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
For part A:
I did a proportion:
OK, good start.
You don't need the length. If the leaf is of uniform thickness (T), then the volume (V) and area (A) are related by:
V=AT
You can solve for the area directly.
Yes.
For part B:
I do not have a calculator handy, so I can't check your number, but I can say that your method is correct. Assuming you did the calculator work correctly, this is A-OK.
Sep2-03, 06:25 PM   #3
about converting the volume of 1.430 cm^3 into m^3, am i correct in doing the following:
(1.430 cm^3)(1m/10^2cm)^3 = 1.430 x10^-6 m^3
is that correct? or should i have just done this:
(1.430 cm^3)(1m/10^2cm) = 1.430 x10^-2 m^3
Sep3-03, 07:07 AM   #4
Recognitions:
Your first calculation is correct. There are 100 cm in a m and so 100^3= 1000000 cubic cm in a cubic m. Although I wonder why yo are converting to cubic meters. Wouldn't it be easier to convert everything to cm?
Thread Closed
Thread Tools
Similar Threads for: mass problem dealing with areas and lengths
Thread Forum Replies
Calculus: volumes, areas, lengths and Work Calculus & Beyond Homework 0
Dealing with mass, acceleration and velocity Introductory Physics Homework 2
Mathmatics-problem on areas General Math 2
Problem dealing with mAH, mA, and volts... Introductory Physics Homework 6
Summation of rectangular areas (calculus) problem. Introductory Physics Homework 4
